E8X Would using the M-sport rear springs help?
Can I use M-Sport Springs on Rear suspension with YCW Shocks?
  • Yeah man!
    Votes: 0 0.0%
  • Probably, but you will have to cut the springs
    Votes: 0 0.0%
  • Total voters
1,923
662
From that response i think you may need stiffer front springs sounds like your hitting bump stops. Do you know what your spring length is and try raising front up real high then going for drive Just for hell of it or if you have seperate pre load and height adjusters forget that and Jack pre load up temporarily.
