windows, turn signal, dash lights electronics issue
Seaneezy
133
34
e90 LCI 335i
Car has been having weird battery issues recently but is throwing no codes for it. For the past two weeks sometimes when I turn the car off, but before taking the key out all electronics in the car go off. Now none of my driver door panel switches work (regulators are fine, rear window switches work in rear seats), my turn signal stalk does nothing (does not initiate signal) and there are no lights on my dash or in my interior(daytime headlights still work). I was thinking it was a fuse because of it's suddenness, but I have replaced 6 fuses related to these functions and nothing changed (the fuses were pretty worn down anyways). My battery voltage is 14.5v when the car is running and 12.5~ when the car is in ignition.
Anyone experience this before?
I found a small cable that wasn't connected to anything near my battery and I have no idea where or if it plugs into anything. It is a 3 pin female connector I'll add pics below.
Optigrab
129
08 135i
Maybe the BSD i cant tell
How old is the battery and was it coded when it was put in?
Vbp6us
93
15
San Diego, CA
Sounds like a fried FRM. I just had the footwell module replaced by the dealer under "good faith" because they fried the existing one (likely going out). Symptoms were what you described.
Optigrab
129
08 135i
Here is what i could find hope it helps
Footwell module (FRM) is the master control module for all exterior
lighting functions. Exterior light systems (headlights and side and
parking lights) are switched ON and OFF by the light switch via the
FRM. The hazard light switch is connected directly to the FRM
Front LED turn signal not working
Cause is either faulty LED front turn signals or a faulty FRM (footwell module)
(E90 I E91 models with Xenon headlights from 07/2008)
Two situations are possible:
• Front left and front right LED turn signals do not work, either intermittently or permanently.
• LED turn signals on vehicle side flash at a higher frequency, either
intermittently or permanently. In the case of such a fault, Check
Control message "Turn indicator defective" appears.
If LED turn signals do not work properly, diagnose using BMW scan
tool.
If LED turn signals work, but either intermittently or permanently has
double-speed flashing frequency, replace LED indicator module in
headlight.
If this does not resolve problem, replace footwell module (FRM).
Further information can be found in BMW Service Bulletin SIB 63 06 09
Reactions: Seaneezy
Optigrab
129
08 135i
Hopefully you are covered under the FRM extended warranty for some models 10 YEARS/156,000 MILES
SI B01 20 16
Warranties August 2018
Technical Service
FOOTWELL MODULE (FRM): LIMITED WARRANTY EXTENSION INCREASED TO 10 YEARS/156,000 MILES
New information provided by this revision is preceded by this symbol .
This Service Information bulletin supersedes SI B01 20 16 dated August 2016
What's New:
• The footwell module (FRM) extended limited warranty has been increased to 10 years/156,000 miles.
  • SI B 01 20 16.pdf
Reactions: Seaneezy
Seaneezy
133
34
e90 LCI 335i
It has got to be the FRM, I'll try communicating with it later tonight to confirm but I made an appointment at the dealership to solve it. Bought a backup FRM module for $30 on ebay in case they don't honor the warranty. It's a 2010 335i with 90k miles, but it's BMW of NA so you never really know.
In the meantime, I got pulled over driving to work because I didn't use my turn signals :sweatsmile:. He let me go after explaining the situation.
Reactions: Optigrab
Optigrab
129
08 135i
Lol like you used them anyway. Looks like you should be covered. Let us know how it goes
