I run the PTE 5862 Gen 1 and it spools very quickly and has no problem making 600whp. I beleive they either just came out with, or are coming out wiht a Gen 2 5862. Personally I love the set up.Decided I want to go the single turbo route, due to reliability and ease of access to the turbo. My goals are at most 600whp and quick spooling. Will be running 94 octane and meth. I was thinking a PT5862 but anyone else have any recommendations?
You have a couple but if you want to make maximum power on pump gas you're looking at either 6466 or 6766
He is not wanting big power. Anyone recommending a 62mm turbo will probably cause someone with this mindset to be disappointed. I have a 6266 and if you only wanted 600, I'd say do something smaller, like the 5862 gen2 if its out. Or maybe a smaller EFR.
Yeah you can run a efr 7670 or the s257 sxe which has the same compressor wheel as the 7670 but it's Journal bearing with an inconel turbine wheel instead of the Gamma Ti. It's also $1,000 cheaper
Wait what? Looking for the falling sky or frozen part of hell......Twin Scroll Garret GEN 2 GTX3076 would be a perfect turbo for your needs
Are there any other companies that are going to a similar material? Like their own branded versions of it?
