What'd you do to your car today??
Hokie_335i
51
24
North Carolina
2009 E90 335i 6MT
Also put on some new shoes and got an alignment. Apex SM-10's with square 255 Conti ExtremeContact Sports.
Alignment specs seem a little wonky. -1.3* camber up front, -2.3* rear. Should I get them to dial it down in the rear?
Please post more pics of these in the light! I'm looking to get a set for my JB e90 and your the first e90 i've seen with them. Thanks!
Bmac
77
34
Great White North
Here you go:
Cheezy
611
225
Toledo Ohio
Yesterday i dropped off my car for new injectors.... finally. Today i pick it up and install new lux angel eyes. Saturday i have a bunch planned but ill post it up then :wink:
Bnks334
530
344
Personally, I'd drop the rear to -1.5*, but that may not be possible with stock adjustment range if the car is lowered.
Venom77
36
27
Arizona
335I
I swapped wastegate springs from 10lb to 14.5lbs. (Holds 28psi to redline now)
I installed a manifold with a 1/4th npt fitting for bov. (Fixed the surge I was hearing)
Found a boost leak and replaced the coupler.
Found the rattle I had and fixed.
Found the vibration issue I was having. Belt is separated on a tire..
Yelled and cussed a lot throughout the day.
All in all a good day. lol
Cheezy
611
225
Toledo Ohio
It's a car day for your boys! Today we have oil change and spark plugs on @Carl Balzer 535xi, and on my e92 we have oil change, occ, oil thermostat lid and caps, front brake pads, wheel stud kit, and hunting down a boost leak :sunglasses: lets go!!!
Reactions: Carl Balzer
Stage5Lurker
2012 E92 335i MSport
Pulled fenders on the 35i so the 275s dont rub anymore. Drives like a whole different car now. And took off the linear throttle option on mhd. I now remember why I kept it. Sometimes gettin sideways isn't fun.
Cheezy
611
225
Toledo Ohio
I miss this thread, and it will be active again. Im considering making my own build thread for something thats already been done 1000 times haha. Since the last time i losted i believe all ive done is bimmerlife tuning coil upgrade and flash to mhd v8 beta e50. I cant wait for the near future when i actually get to work on my car!
Cheezy
611
225
Toledo Ohio
So over the last few days ive been dismantling my car, so far ive changed the trans, and diff fluids, as well as the belt. Yesterday i dropped the subframe, today i removed the oe downpipes, and removed the oe front inlet. Tomorrow im gonna cut out the rear inlet and remove the oe outlets then start piecing her back together with vrsf upgrades. Wish me luck cause this is testing my patience
Cheezy
611
225
Toledo Ohio
Buttoned up my downpipe, inlet, and outlet install today. Car sat for 2wks torn apart waiting on parts, fired up first try with no codes! Also checked my blower motor connection. A lil corroded. 20180108_211914.jpg
