Walk Through: Building High-end Headlights
TwinTurboWagon
217
235
San Diego
SpoolStreeters,
I wanted to share the process of building these custom headlights for this single turbo E90.
At first glance it may just appear that some paint was applied and the angel eyes were removed but internally there were some major changes made and this thread will cover all of those changes.
The "paint + LED angel eyes" is the all-too-common recipe for BMW headlights, yes it can look cool but it doesn't address the purpose of the headlight: light output. Many BMWs are equipped with underwhelming headlights and my goal is to address that by retrofitting quality HID projectors and components to improve light output, intensity, and control.
This headlight build was particularly challenging due the the enormous size of the Porsche 997/Murano projectors used; securely mounting it while making sure aim and rotation were correct, all while confirming that clearances front and rear were acceptable along with up/down movement for the factory auto-leveling system. It really is a dance and all of these clearances came down to a few millimeters.
Sit back, grab a drink, and see what is involved with a high end headlight build!
Evan
Build Specs
- Angel Eye Delete
- Tuned Porsche 997/Murano Bi-Xenon Projectors
- Passive White Demon Eyes
- Universal LED Fog Corner Light
- Molded Shrouds
- Low Gloss Black Bezel and Trim
- New oem Lenses
- Apollo 3 Shrouds
- D1S-D2S Igniters
- Mori xb 5,500k
- OEM Bosch 35w Ballasts
- New OEM Lenses
Let's go....
Yoink!
Q6gpSWhbY0XyhkZfni53JhgrXcLxMPOs4Wwm-9pshvCMkcklbqG8oomPlfmOAUDZRVpj70y6KVtIRGS5Ow=w1318-h988-no.jpg
Headlights were previously modded with the standard BMW cocktail which is paint + LED angel eyes and doesn't address output ....silly headlight "builders" you're doing it wrong!
3xqIJF1bUz_HFv_faIwtrh3-f2WHNeeJ6wrCTlGlwm0gcXOdlvN5SbNR-dwG8f98yK8zV8SS0UtEoxUMQA=w1318-h988-no.jpg
Lenses were in pretty poor condition with the clear coat shot by the previous shop chipping off.
oAlXTHjdH4JR1mAkW0semUhz3p7XzJLIUU47uY14kjo5VtYQI3Pow2vP5wRX3pwMBni4D1FnsQzWQjWshg=w1318-h988-no.jpg
YrKBfNbnD8EBvQiio4pLV5lC3KNAbb4orhvYZkFMBTVxXhiRi2KnbVpCj2CMhj89zWLg_vyy8fqb2f0f6w=w1318-h988-no.jpg
Get in
A_U0uBwsn00I8O6nTH-NnO_UKmhQ--N-QUIo9T1KM7K_Ocl44h9wnsiOVCbVVh0ysFwLxvEAM18-MlgcRA=w1318-h988-no.jpg
Original LED angel eye wire soldering. No bueno
Hsj7STdUFlLMoxEVAt37EqxsF5ZjCSiw3qSH0qPlYDL5R4YRWvvV1F-JSBnQEs7eF7GgBiEkhqs_Oq9u7g=w1318-h988-no.jpg
The original "angel eye installer" didn't remove all the oem permaseal before he resealed with butyl. He and I have different ideas of what a "clean" channel looks like
uRwkUZEIL0LsYSYKP1l729ivewrRyRMRJ59T-59DmDwyLfJhAERhECmwwbnzVrhRh16I1_C2dFGA1Dleqg=w1318-h988-no.jpg
His idea of clean
I1H9uPcOftudz61NJ_uXFq2INobfVMci5XtEWKzxWhHuclpT8_loG1yEpqbpoDHuW_6jO1oIn_sBla5FYQ=w1318-h988-no.jpg
My idea of clean
o-JiuMIRldeki9pEkrnUBkud7CXE3_SBGiyj92-31XD5CDPNd_jBTajEYEfE0glYRJeG8ZfpHoI5D2M15Q=w1318-h988-no.jpg
Much better
3pgOLICe-8CLcrSyKI-XM1r893FqwnnFLl2iQPjf91_8nua0Se7X1vHxympnhJvGqZJ2PPGch0E810B9jg=w1318-h988-no.jpg
Quads were attempted and it would have looked sooooooo good.
ohSdLas2jlxRi_AkKmIbyfLqKt5h-L63tbSz_B-ShmwdCRF1jYKLePG-OGqGqt07WOKcUtrihdS5Z2KQag=w1318-h988-no.jpg
oem angel eye ring + centric ring + H1 7.0 fits like a glove
KXUBS12dXmz8kfoOKMTv9BZ1ai11T0v8FMVvIHyfSTgHeuxpMqa4nKBl-m1Sx-E3qz3KxZYpfRrL-PTcVQ=w1318-h988-no.jpg
The problem would be accessing the bulb if anything happened, the housing car was very small ~2" and you would need to reach over 5" through that hole to reach the the bulb. H1s are already annoying to change so changing this bulb would require needle nose pliers and some skill. Didn't seem worth it from a practical stand point.
ZMRioXoUz702_Vp3GQkZoNvrKKlKfb7XvzGGdisFwXA8fmCuPZWUWRAKADo8FXZVdL-xL4mDFAGslhlj4g=w1318-h988-no.jpg
One difficult bulb change...
lx-E7Zgs553dV373KGntBXrCaz1ZFxujYllX6uKYkdq1-vRCQXAyaNpmMVQQFrKWt9qon0tkGNgJfQtP1Q=w1318-h988-no.jpg
Murano with oem gimbal ....NOPE!
Z5KEntusTMrLjNVq9btIHemlZfgv5FoL6v2L9uOLcoKnW7dODaReKDTEa0hm1vU_FNSk7WaX9OyG_DV0aQ=w1318-h988-no.jpg
Much cutting
m0tHp9SoGJXmbhzX8DMbR3mOosKmT1T3FOZd4KGY13efP3nUg3TP_eZySG1b0UFnVEyX-B09vdas4RhqtQ=w1318-h988-no.jpg
Much better
DZ11vZblxwfYAejpRCWvTNP1dC8wOW7mK7N-l6EPPsd3uGBK3wByCmdWVVepzzHCCCdSYLJE0pxxh0v_ZQ=w1318-h988-no.jpg
Murano sat in front of the gimbal instead of behind
8apn9o5vzd4OBZANWJTHMJgB2CQvI_masiGFvgjtVjtC7hpCxI91rWLcDhtaNVHDDWZqenhkbCT6Bc9L8w=w1318-h988-no.jpg
TwinTurboWagon
217
235
San Diego
Murano fitted to gimbal or gimbal fitted to Murano?
KhhzmfS-h7xbSqo17TCK7UMjXUvUyCX2a117gjoIkgbN4TyYQ46eWDeDxh6C571WMDirXvkyjkVMXyN8RA=w1318-h988-no.jpg
Test fitting shroud clearance, TIGHT!
kmDX8yeDURKvNbqJArkFZ_NVNiLqCCmlCDxY86bFYd6y5yAgZXumrA8FMtR2XHxBooGlKff5U60RWQkFgw=w1318-h988-no.jpg
Looks good though, I like how protrusion of the lens and rake of the shroud match up with the rest of the housing
dBCfYPVC23LNUeO3WCfV1s_D0cPWHXiYepDkhNsTQP5rvWn6DSp-JDwYWv9QUTXOGYhHEj3CMcBSZS1GdA=w1318-h988-no.jpg
Trimmed part of the brow to upper shroud clearance
BULeXB_ZSUNYktNZ2eT67klxy4UFJRkpdkCk9Wa00L4BJK5C0T3tvX6jR8N0fNh4zwtRd0NJ6rTygP43Hg=w1318-h988-no.jpg
With quads not in the cards the next best option was a Morimoto universal fog
Icg66h4R9OK3_vm3W1-cv0jFnc5D4j3E2IwW1FQtlkcVATFfYuN1BeZN77P91rOFoeSAnLNZdYPcOxDgCw=w1318-h988-no.jpg
Trimming up some of the left over plastic from the injection molding
30D0dNydU9KojQ1NtfU59kPvaFWm1DSmLU1BprgLhLwvuYe8-pZTPRbpRI4JPVK6cDlKdqlRwLnxczf6UA=w1318-h988-no.jpg
Graphite shrouds and xb fogs are a good match, I have used the combo before
QhqZ9SC8OMLNWNNbp5Qnc0MVXO7HnLAhWFsdcKpywljEsqoQSf5icq6plotbtQx2l8_1-0XeLNZLkZC_Ew=w1318-h988-no.jpg
Trimming some of the oem angel eye diffuser
4eWWxCPzH5h9PohwvBxDUxFRWRrzlSqzxmIs-H_qQ15r4VMbiGL19RKahXVIb7M1QVrqhk1xkFFwoEIB7A=w1318-h988-no.jpg
Taping the graphite shroud before sanding down the ridges.
SFT2FUVloLceO8yHYhDNW9bYHGTapFBICHehKxWOHtXbKJhhMwCD8c1xyYjOO_0A3tWo7hPPlxoWnZZ3JA=w1318-h988-no.jpg
Test fitting
zqyysvgtAFvOEHs_BJKLX1pTnwT9DQ9-eCCA1P1EP4Ec_NB9Xsq3bH92lPa2zyCw0UaE6g5DGIXJnvfCfw=w1318-h988-no.jpg
More Murano trimming
7G1RZ1dg_P4VCKaSXMHoL_AqgWxaLjDVIdeYLJbK8jj1QjcBhfD3YfxbLxJUsYu0xjfnFLGTt3N7E4AT_w=w1318-h988-no.jpg
Not much left to hold the solenoid to the projector!
ABe5V08Vmk0B-Un9Px_R5iMQBoN5ax8dYe2Fd9QtI4Uycfz8c0TPX0yuaa9wBVxRKVP5fQJr_OvO5cAfrg=w1318-h988-no.jpg
OEM screws are deleted for a bolt pass through, had to convert it for mounting purposes
1kAU5iyp-4JkDSMA1E_7SSSLg4rjDETGk6-KV4Zn9IqHKY8seRiTI5s84CS9nDDuL7_Ohg38eeBZI3OmCA=w1318-h988-no.jpg
Murano shields sanded to remove any imperfections
_RrC8VUsa0wwDfZVhEqCeydxHdwzNR6RuzzWYdkPpMC_QD1QLipWZf4hrFwLH15kNT7DHl13xErf3isvhOogmCfA=s988-no.jpg
White Demon Eye
PzNWZ1NA1UEqyXv1Re4Nld9afFTaB-PLDA5XxBjA5XgS9ocE1YToyeHjiRw7XqMKTY4wyqDE33c0BJopgR739tYA=s988-no.jpg
STI-R Clear Lens
3Cc3SG347oCbCJ5jKrBF_LveGXYHlxA0-wHtjJ1fn2k-o2UXWJzWCIfneEzgW4NTm48SAXm1LLz_a3yfPqztJLYA=s988-no.jpg
OEM
mkx5_GPgfohckwnUvvlL2RIBcECgwlwz0L-H9pPDQ-dgC_OVfAnVCD-inSvn3HBIXh5sGUQagEjWAtip6g=w1318-h988-no.jpg
Passenger
42lY44V4sWIuoIrUeFyY43umU3W1AqdvhYHjDaN8SH069vEy_0-dBiTob3Se4BZOWzS7iuHZ_aJZpl8UPQ=w1318-h988-no.jpg
Driver
CLcr1lR0JA7ILeXYL70RWa0FmR4rxPzjyvbl9QtmNE7EV9sNCVlmlY20RAvKg92Yc3OhUXAjfia8g19A4Q=w1318-h988-no.jpg
More porn
22jSPkhKlK1qWORJMu20L4v388Mhi5P407FMmKIw6UUfNCNcKTVFqtWuAEjkA01RoOaj2Uk1qvKAzcq90g=w1318-h988-no.jpg
TwinTurboWagon
217
235
San Diego
OEM projector beam pattern: Streaky, narrow, excessive foreground, no real hot spot.
0eCmWFgWJMjCX_NjQHKrs3PMJLo1ofY8vctCI-D1wtyTkizcxkF8VcEZmsN2XSGhNnXapKHnPHoez91Lxg=w1318-h988-no.jpg
Murano beam pattern: limited foreground, smoother light output, much wider.
wt1Uu20LZ2Vse7gIlYwZurgCB8eVPcQiWggIHpFira24B6F0J32y4WWmpXx8QHhXmrY3Pg9uDxpe6ciWDw=w1318-h988-no.jpg
OEM projector beam developed a bit
F2F7kCTiaiGShZS3HT5-gDJgZA7AQfJwOwMQ807B8oqMMc1Xc7GiACYRC183A8pXx27OvNIwSm94tA6w1Q=w1318-h988-no.jpg
Murano
OykJoJHiQDMgJ6MmTtoULcx9AcesARhTw-xK4AsEApSzyAmlYlq1R4z3sMZbJIyIcgkSRah3AdYvHIxvyw=w1318-h988-no.jpg
Mounting holes drilled in oem gimbal
j6dZAz5T4Lji06QA-OfvdcwJqeKrqt5MwRlQLVQKDRZ08xdQz5NfF7LtUJnyAOr7UmFkYjfC1LKNr7zQLw=w1318-h988-no.jpg
To better disperse load on the gimbal I added some spacers to fill the pockets in the oem gimbal
IUmIPdqvvCJmYxXQv-HIFWTvkOQhIFFPhAA7BcaLNIE__KwQMK0wZO2vpgEJ16yN45yYRFxiVRv3cLIfdg=w1318-h988-no.jpg
Nut added
mWSitOSRRpjdUs3WnQsgrHqh1RVgngdqQW3FOO2H01KqzJmQ-GwK4dwT68VHGAVB3w2lIwMUz9uVGeKt2Q=w1318-h988-no.jpg
After projector rotation was established I needed to fill the extra space in the slots I made
Iv4dMy_CpVgcdS2Jh0wb7Xg1qmtMZnpMVy6I54U3QyvA5nbwI1Uw3QQNE1IKB9uD4uoh_LXkfczQf6wbpQ=w1318-h988-no.jpg
a5U3-PMRgwewAbX15R9RhPhUfZ2XK2OzAhVYh6VEWhUx41nBp9AGKhrWddmagUKzXwTLjGLkPvbNIrT3Jg=w1318-h988-no.jpg
pj8vTz1QzBpHKczpxdouNNUmkY-2YBOg2K8RLLmK_d1mMwM1_yZ6TQ_OPNEe_pTjD5g_uVPArVavx30nXw=w1318-h988-no.jpg
Added another lower mounting point for stability
qaUjm1ibGCmsLszWSL2mOoUJ6Ful-hu7XjYIMIiqKmjxRvxUFDjq5In5WnZ7mfDoEUQroCZt4AIteKXCXA=w1318-h988-no.jpg
Lower mount added, these were also instrumental in aiming the projector upwards
bl_HR17ZChMl0FWVOYE3x6qCK2XGMKgAvKUwjHQgd2-OSl0tMfG3Aa2P0WslfJHBZqSBmhnnGSlKs8PPmw=w1318-h988-no.jpg
With all the tension on the gimbal from the mounting points the oem ball joint wanted to wander inward and out of the adjuster which made the gimbal a little sloppy, I added a screw and washers to firmly hold the ball joint in position.
POsQ3R7fwlBeoee3GxyW-UkfDyME13lsNyPo3nxw7Q3clSS2hsKznn6wSz0hvhXkrKE2d7salk7hiNPLng=w1318-h988-no.jpg
Projectors mounted!
1h8IxEyFPuSvPpft_3w27rD0MznpZ7YReVnEfhs0yIN-kqsEJQtGjk3FcbxmDxT_KhVkFdaWoggNeFC3sg=w1318-h988-no.jpg
1gd5z24IB4CTWedVrm_VsnTRMuKvdn99oKYDEAUGzx4kiJeprpH389JF9KxGHVu2O6tZsdggylnaFal3Mg=w1318-h988-no.jpg
Once the projectors were locked in it was time to trim the shrouds, top was cut
VOFoD6_zhNUErgD8pZZqTc2FFXslFzWGb9qCAjHSePA2-v_jxeKNHKEbVfPMJvbTSbD27jAIZb9xOjTn6w=w1318-h988-no.jpg
N8HHzoaUrcYvAHxc2681hA7XaNG1DzOrBlx3DRIsZfOPTOTS2bQiiyKQ0EwLCAvYjsJHwBxFYxO7DUjS8Q=w1318-h988-no.jpg
TwinTurboWagon
217
235
San Diego
Bottom was ground down
Q9q_Gz87LD0uGdHnlwKEFqIAi8b5nj5CdbsNJK9Ejo8OcggAtNxI2zHHoRMUqpDnVIOndZ2lEENerv72wQ=w1318-h988-no.jpg
Lower trim was cut and sanded to accommodate some adjustment if needed (in case lights are sold and mounted on a non-lowered vehicle).
REToL4tq8xsh_7IA4rny7cu8z6g0H7gEF9FxJq1a-qaeyGsoVIMLwIg7zOJnaPxhJ4og2b-o28tDW3_ueA=w1318-h988-no.jpg
Oem trim which surrounds the shroud was also cut and trimmed on all 3 sides
GtNRdJDQCD_lu8r_SFxrZo537CpW1qLKJ6ZvMgzgN-amY86JWo8tbkxgqbeOZQ5H62dDh1ViB-w411DO3Q=w1318-h988-no.jpg
Shroud was prepped for wires to add security
oFSnMXCWNSpy3Alg_J7m63oyedQvwA3T978OGMn32LY_oVwXyZ4-DmCOLBuxYoB86s1yjnEhzNUlGu1U0A=w1318-h988-no.jpg
Shrouds painted and mounted with steel epoxy + wires, you can also see the hardware I added to stabilize the headlight adjuster (white plastic arm).
lHYJdfwhWWFy9kuUf6cGQu4ntm_SmbYkVZeHTbFF9CMSC2sH8YhVVCk2c3PHIq0b7XlRig74EwW-OHGblQ=w1318-h988-no.jpg
My solution for mounting the fog to the graphite shroud.
wqx9N3qkf_uqxz9J8Lg7vfK0cXGi80JdXvtY3qdx4l6l8adW2a0ttqE6oF21qHUl6XN4zVYHFdiRWSxc7w=w1318-h988-no.jpg
fog was mounted perpendicular to the shroud so the hardware could mount on the flush surface.
DMp-g90tP-fFl1kbgkBvhT-W70cc_rKmNIgoMa-Zg5aYKA3gk8WDIHPSDSA2WfvU_IC18jWISrZDGwuVow=w1318-h988-no.jpg
angel eye diffuser had cracked
ZjeYxki9guTfAAJBPmWxktVEtYUTbWY2gRpF5_-4yQ9qhLnxAO4bOy0k7up8x922uaLFcBpSBLwgbLM6oA=w1318-h988-no.jpg
So I gave it some steel stitches
JGBcvQLIxQAWwLXce_akE6hoW9ezkoOES-MDRE5Grj2laiWgtp6slAtx0wn3RJDRGAR5Pk_QucrRmFhi1g=w1318-h988-no.jpg
Figuring out fog rotation
MB6SFDqV--jMKD2DjbIUpAugP8F19y54RJUC--IwlehL8sy2vb9_-8c4zXsW-O-tEoB80myQtlADtLhUvg=w1318-h988-no.jpg
Made some access ports so that the fog could be easily mounted after the graphite shroud and oem angel eye diffuser were joined.
DWBJZOovz9HhiY1bY7qebH3eRpDHpQd9RP7LrDr2pRCzlmsZwPbsEivTgbdw2b8N0-hjlSz1DXQxiGA-xA=w1318-h988-no.jpg
TMnPeimgYad3BsOPmhI5hdti75ss15sK3aKYezbzejuU1RFWupBGzi2E1b1YiSmj0QEpKALIA6nex-wyVw=w1318-h988-no.jpg
Graphite shrouds flush- mounted to the oem angel eye diffuser with hardware
ZFYHO1lffzJHG6W7TnQ1Zw-xrDYwyvDlIoK3TDf7EqsvBN_5_cYlY-3Q8IGhqCYqz8Xxv2unph7pCJaOAg=w1318-h988-no.jpg
Clean! Took a bit of time but offers much more peace of mind and security than a sea of JB Weld
pfN73bE7EHD0pcW2y6AEQwdkqNKn9x3NeF5KhSHsrhMeJIIDXNFagbiRf79l50vlGAw_pow9cp7ZHqZBTg=w1318-h988-no.jpg
Shrouds + JB Weld
YWyNJmk3IPfiNPe_bqa5IdO_U4nlzF2Xr9IlGMO3gwtKtLQHQwH_bAdHpYNxgF_qNJFlggiLF46tmhDvKQ=w1318-h988-no.jpg
JB sanded
-1NC9JqzJyUiOvT9FWepoVUYICgcfHu6AX2DoWgX6nuabAYdlkL9QEddjFZAJpiMCIq87FZ04Pto51sNeg=w1318-h988-no.jpg
Spot putty
T5NQWV6-rk-dSknnSQIGV73uwch79ZifGghfl29FRxAglbs79BO8ZMTQPqwnM0hHUrRolzrpv1ryTUlzbw=w1318-h988-no.jpg
Round 1
79vq47NL_yG2uAWiYZiqgsrcWe_7ApJAFkW0a148Es0FB7P9KnSoETwJv0dgk5k4WA2Qgjgp_DodLIAkRg=w1318-h988-no.jpg
Round 2
Bm5Akg5-63kskLTyKI4pj0kyMPbLJMa3cvxSaRVuvnkWKlKk8eVV_arxkUzPliFdByC2j2FeJUGtnZfJZg=w1318-h988-no.jpg
Shrouds painted. Before and After
GCCdceVSRfLGS43Twq90vE-Dxn0hum4CW5b5_jrgxbEO8ODhMU-ihbvDZNmPPPICZFIuTtUErfxFcjkxp3kwbYbA=s988-no.jpg
TwinTurboWagon
217
235
San Diego
Had top trim down some of the hardware so it sat flush in the larger oem shroud
GoI9pNrHunkYzQY2TdaDwGj4W95GZgcAcdvisl2Y8utdr4QFIDjLvlpdOxtvWXqu3S19UtoNSN-EJ36xpQ=w1318-h988-no.jpg
The oem angel eye reflector bow came in handy as once mounted it pinches the molded shrouds inside the larger shroud which made mounting easy.
ViMHSEO3GSx_hKqMvpIO4Y4z6CJM_5Fqj9ri1M5FLoljXcrD7tU4VZ2lk96vn3GFGxpu1gkky760oQpglw=w1318-h988-no.jpg
FsGr9CHjPY4OdhdK_bgbK8MDuoWS47K0XQtr-_VrYhg3LSWd8g3Wl1m284sY40ClPTXdYqsHsUqiC12gUQ=w1318-h988-no.jpg
RIDQUnWd7vaBER67C0G5k814Fz5FRTej3FVyYg9kesEOhFps1_KgZb5poR0ZdkPkbvtMctJTjJdQle0w3w=w1318-h988-no.jpg
Unfortunately I accidently discarded one of the bowls earlier in the build and was kicking myself for doing so. This forced me to come up with another mounting solution for one shroud, this included some JB Weld and another bolt + nut.
udt50QMGgigkubeCEm54YLB8u2Q8xvVUyPR3hArJcTacR1XpbuXw9lV2Adn82hyboLFekVOOqvtog1D_3A=w1318-h988-no.jpg
739cVr_Yhlug8TmkU4Vvzc8YLaHunasYZcD2Cs2T8_iJwTztLmTCpd1LZUbFEwgyqK3C-5Ot1JJ34UvGsQ=w1318-h988-no.jpg
With the fogs all mounted up time to connect them. Fog is wired into oem cornering light so it is more for looks than function.
fj9Tx2h3kWc-CSv1qIsk-P776tJHIaxc1KX9WuhGkQmg4qOr05IFPyuz7w47XhFiJnmM_e5FaEVeKT-2wg=w1318-h988-no.jpg
qbKYzo1RsZxz_PBBlHEF8bQYSzuvVlkqf5JsGO5gcn3nZchCmlqZNUZVdinkUst_ma1FnKC6ntHe9_tN-w=w1318-h988-no.jpg
High beam inputs were soldered (and shrink wrapped of course)
1tM3NajH2O6y-nGw31jRsq0MzwO26hHDOxrQkB2paL0LfeNBCwZvXdjwnNGiETtOSjn_IU9UNk2MdoLFJA=w1318-h988-no.jpg
OEM projector had AFS incorporated into the lens holder which sucks. So on this build AFS was deleted.
8NpSEDGR4YBbr13_FwRJPZPicuADGPE253muJb7rFM_mRr3Dcl0GC7zsKeVUROYSScg8VdfIzVzI3quV-g=w1318-h988-no.jpg
Modules were removed
9Uy-j8xhMN33nKKBe95mqMCZRR25ESUwO0Jcmf2350upPoQsHtn5w-EvPQvapr0WBtjRNjq5FZMeze9ILA=w1318-h988-no.jpg
To keep the CANBUS system without any coding the modules were deconstructed to save room
Vf-8M-sLYdD6-7zlEeBEQ23MD8RE4FI75rTPyKFlAxa64PfkAnhJsQHok3ARycQ992JFqbvtcW9TaKv43Q=w1318-h988-no.jpg
Mounted safely out of the way with some 3M VHB
KBxActDAHvWOfJ1Cw5nHyhY3Mknen68etiR_d2LFKSmLWu0WpJrgfgy7m90-_acI9QU8cqGYX9W5nC3a6w=w1318-h988-no.jpg
The OEM D1S cable was also deconstructed to save space and keep it from hitting the housing during downward projector adjustment
mxGKYycCHNRMQUBrVMY-rosO7ZBzOWay6XUTb-xGaLRbwJ9VvYSL2NOhroJLtcziN7HLzwgKBb4S2fgzMg=w1318-h988-no.jpg
Igniters had to be mounted sideways to keep from hitting the rear housing panel once installed.
hpCg74CcjzaAHzb0IKXqvSckXR1_3DZgMs5gZtgTIvg0UuojNQrRGYX-qo0Lj9G2tUpkueclVX6YbxuMWw=w1318-h988-no.jpg
Lenses were in poor condition inside and out even after some cleaning attempts so new lenses were ordered from Europe.
K6y0oMDXiovKmU95gz9nz67TfYAb-DjfkO3v8Z4WXmdqIHW-jAqRkJ-r6x46JxMJDXkJJ-7Tn2l73a7DiA=w1318-h988-no.jpg
BOOM
3yFqVH_mVNyZAXY3HwEAPr_ZsHZa6lKPRhfLcNcCqYchbC3WewAuoM19NOdmBd0K8K03yvbwJk3wd8WASg=w1318-h988-no.jpg
Some glamour shots with the lens off
RWInbmM8zIWT1gLOTVNtm9ulT03t6x09gv8ikvbgPwQsDkr6hwN0QF7M1gG71gnRlAK8Ck7O2fDAIowgKA=w1318-h988-no.jpg
Csg5S3DDSujzFWwGTVbBnvgczR6GyCKbcol9PEyU2tTgXANNvFwhTJ7xPe24B7iA0oPPq5edw38mnDsT2Q=w1318-h988-no.jpg
ntAxUTTDHQXj_q6FGx-egUyW8-KEX8GegMJ7WhgPM7Uaii7wq7VUawVo7AY5C4blkS9JDGmvb3Ar1Vex0g=w1318-h988-no.jpg
  • Disagree
Reactions: crowdedthehouse
Kervio
43
15
turned out amazing! A lot of janky stuff needs to be done behind the scenes to get everything to work but the end product is beautiful
TwinTurboWagon
217
235
San Diego
Absolutely! Didn't mean to come off like I was insulting your work, they turned out great
I didn't take it that way. We are all good. I was simply stating all the stuff behind the scenes that you don't see if common for retrofitting since it looks so simple when viewed from the front but little do most people know all the creative solutions that went into it.
Evan
Jsherry20
313
With having an extra set of headlights layin around I really need to test my skills at building headlights
Jsherry20
313
An extra set is the best set to practice on!
That's what I thought too, I got backed into and the headlights had a broken tab but it really didn't bother me, however the insurance agency let me keep them lol. So I'll give it a shot. I dabbled with my cobalt SS headlights a bit and I just get scared trying to seal the lenses to the housing. Hopefully it's pretty easy with these.
rebo0t
59
13
E90 335i
I just received my Morimoto Mini 4.0's today, going to try something soon :)
