VTT VC and Catch Can setup oil consumption
Reformatt
81
41
Houston
2010 335i E92
Are you talking about https://vargasturbo.com/product/vtt-billet-vacuum-relief-valve/
What amount would you set it to? Also, I thought I remember reading awhile back that some people had problems with this hitting the hood. I tried to search and I am not seeing it so not sure what I was reading but do you know if it is true?
Depending on which version of valve cover an model of car I believe E92 is a issue E90 wasn’t but I could be wrong..All I did was install the vacuum relief on upper head port on the front side of the engine..No comments on my dirty engine bay..I am sure I took this photo after some long evening of putting the car back together…
