VTT Rocker Cover
Brought this a little while ago and getting it custom painted, not finished yet.
Should be fitted in a week or two.
Looks amazing, the quality of this rocker cover is awesome and is priced very well.
To tell you the truth I haven't weighed it as it feels around the same to me.
I pick it up on Friday so I'll weight it for you.
Seriously guys this cover turned out awesome, pictures just don't do it justice how sic it looks.
Cant wait to fit this with my custom coil cover and polished di rail and lines.
4,348
Can you elaborate on the coil cover? I've been asking about that for months to pretty much anyone who would listen...But nobody ever does. These wires are fugly.
The Convert
1,487
1,054
Valve cover looks good. The only two things I don't like about this offering is they don't use a baffle underneath the port fittings to prevent straight liquid from getting out and the way the fuel lines fit over the intake cam cover. I wish they would have raised the intake side higher and machined a gutter for each fuel line so they "tucked" in. Then they could have added a carbon cover to cover the exhaust cam, harness, coils, and injectors.
Every cover i seen so far is the same, just the finish, angles of cover and machining looked a fair bit better on the vtt and appealed to what I'm after
