There's a rivet holding the horn bracket on, you can see it in between the two studs. I could be mistaken but it might be riveted onto the other side of the frame rail. You can use a drill bit extension to lightly drill it out. There are two of these rivets, another one by the top two studs accessible by a hole in the headlight washer bracket. Again, not sure if that's stopping the crash bar from coming off
