Trans in wrong gear after service
Dubshu
2006 530I
Did a service on my 06 530i with the 6HP19Z, new solenoids, new bridge seal, new sleeve, new fluid and pan. Shifter would move, actually trans wouldn't engage. Fluid level is good. Found tonight with my scanner that when the shifter is in Park, nuetral and drive the trans is actually in 1st gear. It will actually try to move in nuetral. What did I mess up and more importantly how do I fix??
Dubshu
2006 530I
This. Try to catch the fluid in a clean container and reuse it.
Welp, just dropped the pan and the shift arm was actually engaged correctly. Now however it shows to be in 3rd gear while the shifter is in Park, reverse, nuetral and drive. Prior it was showing 1st gear in Park, nuetral and drive. I have my scanner hooked up to check the gears, how do I fix this??
Dubshu
2006 530I
Dubshu
2006 530I
This is my shifter position with the vehicle in Park, the plunger is pushed towards the engine.
