TPMS fault
Kenjermen
78
75
N las vegas NV
hey im looking for some help on my E60, i already tried to unplug/swap the TPMS module and it still has the malfunction light. My next guess is its the transmitter/receiver so do anyone of you know where that is located? i heard its in the wheel cover but dont know where or which one.
4,344
That depends on which sensor. If you are talking about the front sensors, on my E93 the receivers are boxes that are literally on the interior of the plastic fender liner, the harness goes into the same loom as the fog lights on my car. On the rear, they are either behind the liner or on the undercarriage hidden by some of that felt covering. I forgot.
dyezak
1,767
1,518
Plano TX
335is
Any tire shop will check the sensors for free with the tool. Just go to your nearest discount tire.
Kenjermen
78
75
N las vegas NV
So finally had time to take the car apart, there are 4 transmitters one in the back of each fender inside the wheel arch, also the module is located in trunk on the left side wall, non of these fixed it and now I think I have bad tmps in the wheels, luckily this didn't cost me anything but my time do to me already having the parts from my 335i that doesn't use this system anymore
dyezak
1,767
1,518
Plano TX
335is
Make sure the parts are compatible, cars before 09/2009 had different frequency sensors than those after that build date. So a 2008 would be incompatible with a 2011 for example.
Reactions: Kenjermen
dyezak
1,767
1,518
Plano TX
335is
The 2010 will definitely have the new style (I think 433mhz) sensors. But the 2009 could have the new ones or the old ones. You'll need to run the part numbers to see as they visually look the same. Or you can run the VIN of the 2009 car through the BMW Vin Decoder and see what the build date was.
