Titan Motorsports Forgestar F14 Drag Pack
Titan Motorsports has partnered with Forgestar to develope the ultimate Supra MKV Drag Pack . The front wheels are 17x4.5 skinnies weighing in at 15lbs, the rears a 17x10.5 which weigh approximately 19lbs. Available in a durable matte black finish, we are now taking pre-orders for these and anticipate they will be available for shipping worldwide in November, introductory pricing is For ONLY $1,399 for the complete set of 4 (these will not be available in pairs).
Features & Details
· F14 Drag Edition Wheel
· Race Inspired Mesh Design
· Rotary Forged Flow Formed Barrel - Light and Strong
· Durable Satin Matte Finish
· One Piece Aluminum Wheel
· Bead Seat Knurling
· Supports up to 1520 lbs each corner
Looking for something different when it comes to drag wheels? If so, Forgestar has the answer in the form of their F14 Drag Edition Wheel. This Forgestar Drag Wheel has the same aggressive 14 spoke mesh design as their F14 wheel only in the appropriate 17x10.5 size for use on the drag strip.
Forgestar uses a unique Rotary Forged Flowforming process that both lightens and strengthens the wheel. The process starts with a low pressure aluminum casting that is set in a special machine that spins and heats the outer barrel of the wheel, then steel rollers press against the barrel to pull the rim into its final width and shape. The combination of the heat, pressure and spinning creates a barrel with the strength similar to that of a forged wheel.
The F14 Drag Edition Wheels feature bead seat knurling, a pattern of straight grooved lines that are machined into the bead seat of the wheel to provide a surface for the tire to grip into when mounted. This knurling helps to prevent the tire from slipping or spinning around the rim during hard launches.
Forgestar F14 Drag Edition Wheels are street legal when combined with a DOT approved tire. This provides an ultimately convenient way to get to the track, race your Supra and drive home all using the same set of wheels and tires. Add cool modern styling to your 2020 MKV Supra while blasting down the track with a set of Forgestar Drag Edition Wheels.
31382
31383
