Tables to modify to decrease dsc control
Nick1224
08 335i 6mt
I have been having issues with dsc throwing me into fuel code 15 while at autox (on a track with crappy surface). Then I go into limp mode and my run is toast. I'm not ready to drop a lsd in yet, so was wondering if there was a way to decrease the amount the dme can control torque.
08 335i 6mt fbo on e85
That would be a question probably for @jyamona
Perhaps other tuners are aware of how to do this, but I don't know how any of that works personally.
cookiesowns
26
7
2010 535i ZHP6 + 2017 M2 6MT
What car? Might be able to code DSC module to add in "Euro MDM" so to speak on a non M car. That said, are you running with DSC completely off? If not, why not?
1,616
2,083
I can stop DSC intervention all together on the DME side, or make one press act like full off. However, I can't tweak how much torque gets reduced. That request comes from the DSC module itself, based on the amount of wheel spin.
dzid_
54
36
US
135i 2011 DCT
Do you know if there is a way to keep Sport button mode active when DSC active (one press)?
On my 135i 2011, when DSC is active, I am losing turbo lag reduction that Sport button is giving. Only higher shiftpoints are there.
Bnks334
530
344
New York
You can change parameters in the dsc module to change the slip angle and torque factors but it's not perfect. Just turn it all the way off and learn to drive your car.
Reactions: Jake@MHD
tony@codewerx
172
40
E92
Would not recommend turning the ediff off ... the rest of it is fine in the dsc.
Raising the cells torque intervention table may help ..
