Syvecs with E6x N54
RBSileighty
09 E61 535ixT 6mt
I was under the impression we could use ECU's between platforms (ie. E90 can use a E60 ecu)... if this is untrue this will end quickly.
I wrote Syvecs and they said their ECU won't work with an E6x platform and I would love to hear everyone's thoughts. Does anyone know if you can control X-Drive with Syvecs on the 335 X-Drive cars?
Thank you for your time and help!
2,251
804
Im just guessing here but I think the standard roms all contain enough data to be used with all N54s. but the syvecs was made from scratch for a 3 series n54 and so doesn’t have it.
This doesnt mean it cant be done, it may not have been done yet....
CenTXe92
21
14
Austin, Texas
'90 335i Coupe 6MT
To clarify a couple things. Syvecs can control anything you can calibrate. The reason the n54 pnp kit won't work in other platforms is there is a fair amount of CAN data to control some functions. It wouldn't match other chassis. You could use it as a starting point, but you'd still have your work cut out for you. Also, there are no "roms", it's a purpose built database.
Reactions: aus335iguy
