There is a gap in the steering wheel box, so what can be the reason for you, which means I do not change the direction of the car when I turn the steering slightly to the right or to the left.
There's a troubleshooting sub forum as a heads up for faster response.
Now, this is important
If you removed your steering rack recently (downpipe install maybe?) and re used the two aluminum bolts, get back under the car and check them immediately. Dangerous AF
Everyone else heed that warning. They're $10 to replace and are one time use bolts.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
