Speedtech kit feedback
That Affirm option is the dumbest thing you can do.
Apply for a credit card and put it on that, lower interest. By far.
If you take my advice you'll be in good shape or go apply for a 6k credit limit and bomb that credit score
335insanity
09 335XI
i have no credit LOL, i'm in college and prefer cash fuck loans of any kind is how i roll just don't like big bro having any hands in my pocket except for taxes:tearsofjoy:
Reactions: ajpagosa
Bmxr152
Lake tahoe
N54 e90 single turbo
Does anyone have a recommendation for a turbo that spools at or before 4k rpm and that is able to make upwards of 600whp on pump 93? I'm not looking to run a percision by the way. On my evo i had a 6466 and 6266 that only lasted 5-7k miles on both of those builds when my holstet lasted 20k+ miles. I'm thinking of a s362 or a garret gtw3476
As far as tuning the boostbox it works fine on my st car. Just plugged it in and away I went. Very simple.
I would pick the speedtech kit over Doc Race any day.
Why out of curiosity?
You are going to need a big turbo to hit 600 on 93 alone. Larger than a 6466 which is a 90 lb/min turbo. You will want to run cp or dp meth to get to hit your goal of 600whp on 93 or have a very large laggy turbo...
That garret 3476 is a 70 lb/min turbo way too small. You will need 100 lb/min turbo or larger to hit 600whp on 93 alone.
A precision rebuild is what 700? They should last longer than 5k miles regardless. Not par for the course from what I have seen from precision. Were yours new or used? Did you send them back for rebuilds? What failed on each turbo? Did you use an oil restrictor?
Reactions: RuskiRacer
Bmxr152
Lake tahoe
The turbos were brand new when I used them, but that was like 7-8 years ago. So I will be using flex fuel if I need to but was hoping to hit at least 560whp on pump like i am now with the twins that just blew up. I am running a mix of 93 and 100 octane and i see almost zero knock.
So I can get a really good deal on a brand new speedtech kit with bb 6266 that is ready to ship or I can wait and pay about another 600$ and get a gtw3884r bb turbo kit. I know the garret is a 64 compressor so it would be better suited for higher power levels but I'm wondering if the spool would be similar to the 6266 but will more reliability?
Well a 6266 seems to make around 550whp on 93 alone:
A 6266 is rated for 800hp and 6466 900 hp.
That garret gtw3884r is like 85 lb/min compared to 90 lb/min the 6466 so rather comparable on output not that lb/min tells everything and there is no compressor maps for the precisions.
Unfortunately you need a fair amount of turbo to make good numbers on straight 93 on the n54. My suggestion would be to run meth as it is cheap and the gains are good.
Not going to go wrong with that gtw3884r. I would spend the 600 more and get the superior designed and larger turbo. It will also get you closer to your goals. But really, run meth if you have no e85 access.
Which twins shit the bed?
Bmxr152
Lake tahoe
Yeah I think that's what I'm going to do then! Gtw3884r it is. Hopefully spool up isnt too bad!
Your going to laugh but I took a chance and bought tomioka 15t turbos because they were cheap and my stockers were throwing 30ff codes. I ran them for a out 12k miles and multiple half mile pulls up to 160+mph. They ran really well up till I went into 6th hitting 24psi and smoke cloud. I will send them in for warranty and sell them as well as all my other twin bolt ons. It was flowing 57lbs min at 24psi and running 96 octane
Luckily I'm a tech at a lexus dealership which is attached to a bmw dealership so I have access to anything bmw, so the labor part isnt that big of a deal. I just want things reliable and done right.
gixercho
57
42
E92 335i Custom ST
Garrett GTX/GTX gen2 3582 or Precision 6266 are more then enough to hit 600whp on 93-94 octane pump if you have enough fuel to do it(PI or hpfp overdrive kit). Personaly on my car 3582 maxed out the hpfp at 562whp with 93/94 octane and if i had just a little more fuel the 600whp wolud be no problem. And no when i am thinking about it on dyno the boost didnt hit the same levels like on the road so may be the car was 600whp on the road where the boost was there.
Bmxr152
Lake tahoe
So I ended up going with the gtw3884r with the 62mm compressor paired to a 1.0ar turbine housing. I will also be installing a water meth kit at the same time. I got the solenoid and 2ill be running 2 smaller nozzles to help with atomization.
Btw devils own is having 50% deals on their stage 1 kits this weekend!!
Reactions: WOT808 and Torgus
_Calle_
52
24
Germany
e82 135is
I have the Speedtech kit at home, it has a really nice quality and the design is thoughtfully all the way.
I prefer the Bottom mound kit´s, less heat in the engine bay, no melted valve cover and so on, and it looks stock in the first view.
I run the kit with a GTW3684R with the small 0.70 A/R, Yes it will have less max power regarding a 1.00 A/R. But I have the focus on spool.
The boost will controlled with a CANChecked Data Display with boostcontroller and a 4-port MAC.
Reactions: WOT808
Bmxr152
Lake tahoe
All installed and running great. I went with the gtw3884r in 6265 form with a 1.0ar. Spool is like stock and pulls till redline
Reactions: mattpins and WOT808
