FS Single turbo e90 6mt 6766 w/ t51r mod
Gencheezzy
27
e90 335i 6mt
looking for 18.5k on stock wheels or 20k on bbs wheels
If interested send me a message here or for a faster response on instagram @gencheezy
Car has 83k miles
Mod list:
-Custom bottom mount kit precision turbo 6766 w/ t51r mod (sounds insane!), tial wg, dump pipe
- stage 3 lpfp (dual walboro 450s w/ 15psi hobb switch
- Flex fuel analyzer which shoes exactly how much ethanol is in the tank and you can fill any amount due to me having a flexfuel tune on the car. No need to test ethanol each time. Motiv flexfuel kit
- upgraded fuel lines with an fittings
- pr ignition coils
- ngk 95770 spark plugs gapped at .020
-custom oil cooler( rb block off plate, vibrant performance lines and fittings, improved racing external tstat, 25 row cooler)
- csf aluminum radiator
- vrsf 7.5” intercooler
- xclutch twin disc clutch kit
- custom headlights cost me $1350 (only know one other guy with this type of set)
- upgraded pcv setup( lines running down to tranny to ignore all fumes or smell)
- m3 cowl conversion
- f80 m3 calipers 4 piston with 370mm rotors
- mhd all licenses
- aem afr gauge
- go fast bits gforce 3 electronic boost gauge
- car comes with heated seats, red seat belts, lci rear conversion, has comfort access package (tail lights and trunk and mtech rear bumper)
-vanguard custom fabbed exhaust to fit single kit sounds amazing!!!
- BBS RI-A wheels cost 3.6k usd came from japan
- Quaife lsd 3.56 ratio
- zhp shiftknob
- custom f80 style cluster
- bilstein pss10 b16 fully adjustable coilovers
- every mod has been recoreded have over 60 pages of records including window sticker from 07’.
