Short shifters
Euro venom
95
94
Tualatin, or
Hey friends, I'm in need to do my shift linkage in my '08 135i, (She feels like a sloppy hoe.) But I want to just do a short shifter kit while I'm at it. Who has done one and is happy with the results?
Thanks!
335i_lou
82
30
Raleigh, NC
E90 335i, FBO, inlets, outlets
Ì have the RTD shifter and it feels great! The shifts are very crisp, notchy, and direct. But it seems to rattle a good bit and has this occasional “clinking” sound... going to get under the car this weekend and see if something is loose.. but otherwise, it’s amazing!
Reactions: Euro venom
Euro venom
95
94
Tualatin, or
Thank you! I'll look them up!
Reactions: 335i_lou
camberadam
257
106
Baltimore
Tasmin Green e92
RTD is just too tall for my taste. I have the UUC shifter w/ a heavy stainless knob, BMS shift rod & like it.
Bmwfixerguy1
875
292
07 335i MT
I'm putting an RTD race one in with my spec 3+, trans reseal, brass fork pivot and single mass fly wheel.
I'll be removing a B&M ssk, bms shift rod and alcantara BMW performance knob
Text me if your interested, I also plan on parts warrantying my 550 clutch so will have a brand new 550/335is clutch kit as well if interested
6094723419
Hokie_335i
51
24
North Carolina
2009 E90 335i 6MT
Been looking into the RTD shifter as well recently. Had the BMW SS kit in my last 335 but it wasn't much different than stock. Still sloppy
Arhoads335i
40
15
6094723419
609 number? I’ll take that stuff I’m in Hopewell nj
Bnks334
530
344
A short shift kit will not eliminate slop. The slop is in the shifter carrier bushings.
https://www.ecstuning.com/b-genuine...btijB7a_puMlMu1i3B27bHkF7hOW0gChoCL9AQAvD_BwE
The two shifter bushings at the front can be replaced with Delrin (https://www.akgmotorsport.com/produ...-delrin-oval-e8x-e9x-z4-2-5si-z4-3-0i-2006/); however, most of the slop actually comes from the 3rd mounting point (the Shifter Arm Bushing). This bushing has no stiffer replacement as far as i know (maybe look into the IS part?). I filled mine with polyurethane myself which significantly reduced the amount of shifter movement.
The other point of slop is that the stock selector arm only mounts to one point. A dual sheer selector rod (DSSR) eliminates a bit more of the slop.
http://store.uucmotorwerks.com/dssr...5i-12009-production-date-and-later-p1291.aspx
Instead of going with a SSK, upgraded carrier bushings, and the DSSR, you can buy a shift kit that replaces the entire stock assembly (something like the RTD shifter).
Great post, the rtd seems to be a popular choice lately, where as before the dssr and ssk was all we heard about.
I'm wondering if that company will make one of those sequential style shifters for this car.
Alex
18
Bay Area
2007 E92 335i MT
If you're gonna run the RTD, it is highly recommended that you run stiff or solid trans mounts, main difference between OEM style and RTD is that the RTD carrier is mounted to the car so when cornering, your trans moves while your shifter/carrier stays stationary so gear locations relative to the knob can change without stiff trans mounts. The OEM style just pivots on a bushing mounted to the car but is mainly mounted to the trans. I drove an RTD e46 m3 and had slightly more side to side play than my BMS SSK but then again i shimmed my DSSR to have absolutely no play. You will also want to change the foam bushing where the selector rod connects to the trans.
LoBoost
251
172
2008 135i, 2014 GTR
I ordered the RTD shifter back on January 9th and it still hasn’t shown up in the mail. I ordered direct from RTD. I Assume these are made per order and not stocked, and that’s why it’s taking so long.
Just something to consider, if you order from RTD it may take a while to get your stuff.
1,678
Says on their site they're made to order with a 4-6 week lead time.
LoBoost
251
172
2008 135i, 2014 GTR
What’s their website address? rtdshifting.com loads and says offline every time I check it. I ordered the shifter via email.
LoBoost
251
172
2008 135i, 2014 GTR
