Schrick Cams for the N54 Finally!
Joe
Arizona
No need. We have dual VANOS with a big range. Idle would still be silky smooth after tuning with consistent manifold vacuum.
Yup. Still need ghost cam for real cams, lol.
Sounds like its throwing alot of codes in the last vid. Wonder how its running.
Well it is a brand new motor as well if I remember. Closed deck build with all the bells and whistles. You sure that isn't just the seat belt chime?
Seat belt chime. Several hundred miles on the 268 high lift, still no codes. Car is running great, just started the i8a0s boostbox tuning with Jake. Car spools fucking fast even with 1.03ar... 0 wgdc hitting wg (17.4lbs) at 3750rpm.
Still some bugs in the i8a0s tune, they have ije0s nailed down from the sound of it. Hopefully more progress tomorrow.
Rygart
335xi
Final result yet?
So, sounds like @Joe got his car running with the high lift cams which is good news considering VTT had some issues on their installation. Hopefully his car stays running and we can get some results. Here are a few videos posted on FB:
Joe
Arizona
Had some issues with boost control, various leaks, and some more mods to add. Car should be done in a few weeks, goal is to be ready for Wannagofast end of May. Sorry for the slow progress.
Seaneezy
133
34
e90 LCI 335i
Will she make it?
gmagnus7
174
73
135i N54
Anyone see any gains on stock head/valve train? Any before and after? Wondering if it's worth it to compliment upgraded twins for a better top end.
V8bait
501
773
Texas
Being real here, you shouldn't invest in cams until you've at least committed to a basic port job, which is the low hanging fruit for flow/power. Just going by the numbers here.
Reactions: tisdrew
3,596
Unfortunately we are changing a bunch of things at one time (including turbos), so we won't be able to provide any before/after information because of the too many moving pieces problem. I bought Sean's low-lift Schrick cams to go with the head we are porting. I doubt I would have bought the cams with the head being stock. Unfortunately there is little real information on this choice, at least from my browsing the web. Well except for some of the info VTT posted, which I appreciated. Other than that, I'd likely follow @V8bait's view on this, given his experience and knowledge.
The hard part is, it gets to be an expensive endeavor. You likely buy a spare head for porting, have the machine shop dip the head to clean it, inspect, and do any milling necessary to the face, have someone port/polish it, buy parts for installing the head, on a low-lift cam you will at least do valve seals (I've understood stock springs are fine for the low-lift, but I'm not 100% sure of this yet), on higher lift cams, one is looking at springs and retainers ... and maybe valves depending on what one is doing with their motor. Assuming you know how to do all the work to pull the head apart, assemble the head and install it yourself, I'm guessing this is a minimum $3.5-4.5k exercise (stock valvetrain with cams, add another $800 if doing springs, and another $800 if doing valves). And then, I suspect, you need someone to tune the car that knows how to deal with the curveball thrown at the car when the cams behave differently than what the VANOS/DME expect. I think Justin's "being real here" was likely spot on.
