S366 bottom mount + VTT Double Barrel, motor mounts?
iminhell1
419
207
So this is the one thing I'm fretting about.
How much is the engine going to move?
Do I want to do a stiffer mount right away or can I get by with stock IS mount?
From pictures it looks like the DBBL is tight, I've no clue on the turbo, zero pictures out there.
1,685
I'd go with something like revshift to start which will allow you to play around with rigidity a bit. Then go solid if necessary.
Absolutely absolutely hate to think about the IS mounts being sufficient when new, imperceptibly breaking down over time and ruining your bottom mount kit as they wear out.
