Went from VRSF stepped 5” FMIC to 7” HD FMIC. Note: Replaced radiator during this install, so pictures may show extra room around FMIC work area.
What you’ll get:
http://www.vr-speed.com/vrsf-7-front-mount-intercooler-fmic-kit-135i-335i-n54-e82-e90-e92.html
Where’d it go:
What to do:
Comparing the two FMICs:
Logs: Datazap log: https://goo.gl/MdJi96
Hope this helps anyone (still) shopping for FMICs or considering the 7" HD. Unfortunately before storage, I had a boost leak and a leaky radiator that prevented some good logs of the 5" on the way to the garage. If I have any relative logs that I dig up, I'll post them.
What you’ll get:
- 7” HD FMIC
- 2 black silicone couplers
- 4 T-bar clamps
- 2 Stainless steel 18-8, #14 screws, 1-¼” (#2339 on boltdepot.com)
- Lower charge pipe (if applicable)
- 07 E92 6MT, 113k
- BMS DCI, VRSF DPs + Charge Pipe, MHD v7.1 Stg2+
What to do:
- There are plenty of DIYs from stock on the install: http://billswebspace.com/335HelixIntercoolerDIY.htm, http://www.e90post.com/forums/showthread.php?t=91461
Cliffs:
- Car: Raise car onto jack stands/ramps, remove front shield, remove radiator fan.
- Old IC: disconnect stock couplers, remove lower IC air guide and screws, pull old IC.
- Trim shroud and clean area. This needs to be cut out:
and turned into this:
- New IC: Install lower charge pipe (if applicable), couplers, and new IC.
- Note: May help to have second set of hands or jack when screwing in FMIC. I also used SS hex bolts and washers from Lowes, matching the threads via the screws provided. (http://www.e90post.com/forums/showthread.php?t=1326832)
- The 7” HD core adds some weight, but the fin density is very noticeable. Fit and finish is decent. Solid piece. Mounted up perfectly, just like the 5” stepped.
- Log is 3rd gear shifting into 4th, then letting off at the bottom of 5th gear. IAT held pretty well. I overlaid two end points of each gear so you could see where the temps began and ended.
- Started at 54 F, dropped to 50 F after 3rd gear, up to 59 F top of 4th, and reached 63 F as I was slowing down in 5th.
3rd Gear:
4th Gear:
4th Gear:
Pics:
Toothy face only a mother could love.
Huge shoutout to @doublespaces and @[email protected] for making this happen. Bonus points to Datazap in being able to show these logs easily. Toothy face only a mother could love.
