RB external PCV setup
SingleTurboE92
199
108
Aubrey, Texas
I personally have it, I have not ran it yet but think it is absolutely necessary if you have any form of upgraded turbos. The CCV system on this car was not designed for the amount of boost we are pushing.
SingleTurboE92
199
108
Aubrey, Texas
Andy has a similar kit. It is a flapper delete fitting and a delete on the PCV valve. All of this would run to his amazing catch can that mounts to the strut bar. Look on his site for the fittings and kit. I think he is currently out of one of his fittings but could be wrong. I got the fittings for the RB external catch for free when I bought my new head otherwise I would have considered Andys solution.
DirtKurt
180
196
NH
I've been running the rb external pcv with head ports tapped and plugged since the spring. It works extremely well and keeps the correct vacuum on the crankcase during cruise and idle. It catches oil at a rate of about 4 times to the bms boost side can which I am also running.
2,198
I have it. It's fine but haven't put many miles on it. Install is not too bad, good excuse to do your VC & enlarge your BOV line to 1/4'' while you are in there. Kit fit fine, no install issues or anything unexpected.
  • Love
Reactions: Mikeh1989
randamjam
Cincinnati
I use this kit on my 145k n54, works wonders! I drive 1k+ trips at least once a month, this really helps from excess carbon build up on the valves.
Skeletors_e90
15
11
Florida
I want this on my car but want it all in braided line with AN fittings, is that a possibility? Sorry, I'm trying to currently swap my BMS OCC over to hard line and ANs too. My ocd wants it all to match!!!
Erichale77
827
447
Clearwater, FL
07 E92 coupe
Thats what i did. Except for hard line. Just braided with dual mishimoto cans. Two lines in pic are now braided. IMG_0234.jpg
Rob@RBTurbo
626
404
St. Louis, MO USA
www.rbturbo.com
'08 335i, '14 M6, '15 Tundra
We've had these kits in production for over a year now and the only complaint seems to be the lack of catch can adapter for a cleaner install (which we understand but have not had the time to produce). Other than this the feedback has been excellent and everyone seems to be very content and some elated. Up until recently we haven't even had the moment to add them to the website but they are there finally :)
http://www.rbturbo.com/products/accessories/rb-n54-external-pcv-kit
(FYI we are out of stock currently and another batch is currently being machined)
TurboMike
113
PA
Well you have an order coming from me here soon. Any other cool R&D going on over there?
R.G.
668
328
Henderson, NV
E92 335, F10 M5
EDIT**
What is the "Throttle body adaptation assembly" in the kit? The PCV delete?
R.G.
668
328
Henderson, NV
E92 335, F10 M5
Trying to wrap my head around this kit, maybe someone who understands it better can chime in.
This kit has a flapper delete which is the lower valve of the 2, correct? Comes with an adapter to allow decel venting to a catch can which then plugs in to.... the throttle body? So the pressure vent valve stays in place routed to catch can/VTA whatever, correct?
phv628
10
-8
USA
2009 335i xDrive
The RB kit does not have a flapper delete. Use the BMS or AD-E kit for that side. The RB kit externalizes the PCV to a catch can and pulls vacuum using the throttle body adapter which is included. You would VTA on the flapper side with the BMS or AD-E kits.
  • Dumb
Reactions: 9krpmrx8 and R.G.
