Question about oil in my 525i
MacBB55
80
Northern California
2004 BMW 525I
I have a 04 525i an just noticed that the oil I added this morning wasn't synthetic, it was 5w-30 just not synthetic, I know whats in it is so im wondering if adding a lil over a half a quart today is going to cause any harm to the point I should drain it and do a complete change?
1,928
660
No you don't have to drain it wouldnt be a bad idea to search voa on both oil types because some add packs can counter each other and hurt film strength and such. But half quart isn't really issue
MacBB55
80
Northern California
2004 BMW 525I
k will do, yea at most it wasn't much more than a half court, one thing I have noticed since realizing this issue is that it seems as if now somewhere around my oil filter housing is leaking as well as a slight drip when the car is running from under it, im guessing from where the plug is but I haven't been able to go under there to check fully yet. right now my concern is more towards the filter housing leaking from somewhere because I know that before running that half quart I didn't have any oil leaks except for the sligt drip from time to time
1,928
660
I would set oil cap again and check o ring ofhg wouldnt start ti leak because of little dino.
