SOLD Price reduced - 6hp21 Updated Torque Converter $200 + shipping
Status
Not open for further replies.
Selling a remanufactured upgraded torque converter from Transtar Industries - ZF authorized dealer. It has updated ZF clutch discs inside and replaced all spline/gears/o rings, seals. Six bolt unit. See pics. Less than 1 mile on from testing on my old tranny...which was traded in for an entire new tranny so I have no use for it except for backup if necessary.
See pics.
$200 plus shipping. Thanks for your interest.
VT
Hassans
69
15
E90 LCI 335i N54
what are the benefits over the stock TC? Is it just the most up to date version with new parts?
Bingo. It is my understanding that these remanufactured units use the most up to date new parts and any older flawed designs were replaced - thus they are the "upgraded" versions. At least that is what the sales guy told me. If I were him, I would say, they are the "updated" versions instead of the "upgraded" versions.
Still, testing this unit out there was a very noticeable difference from my old worn out unit with 70k miles on it.
To compare the two units, I set them both on their hard center nubs with the open hole facing upwards.
Then I would use the center hard nubs as a pivot point and quickly sway the units as far left and right as possible.
On the original stock used unit, there were loud and hard klanging and banging of inside parts hitting each other, all loose like.
On the updated unit there was almost no sounds or looseness.
During the one mile test, I noticed tighter response, quicker response to acceleration input.
Felt like a car feels when you drive it off a lot brand new.
Jboyorak
14
Maine
200 plus shipping? I don't have good access to the net right now with my power out, what years came with the 6 bolt mount? Mine is a 2008. If it works I'll take it for sure
Shipping would be to 04005 zip.
You absolutely must makensure you have a 6hp21 tranny. This not for 6hp19. The 6hp21 (zf nomenclature) is designated as 6hp19TU by BMW. (Technical update.)
Before pulling the trigger find out for sure that you have the 6hp21 with these bolts.
There is no refund if you err.
PM me your email to discuss further.
Thanks
VT
4,348
Thanks
VT
Correct, 6HP19Z, 6HP19TU, 6HP21, all depending on what literature you're reading. Different companies and texts and databases will refer to the transmission in different ways.
Status
