PR Boot Removal Help
BOosted 335i
315
104
New Jersey
E90 BMW 335i
Wanted to check my plugs and having a issue removing my PR Coil boot from my plugs.they are on very tight and my boots sit little inside the plug hole,whats the best way to remove them?
Ruslik
Like it tore in half and the rubber piece is still on the plug?
I used thin long nosehead pliers to get it off and out.
Panzerfaust
635
438
Chicago
E92 335i
I don't have them personally but I heavily considered them and spoke to PR about them a lot. My understanding is you lift up the "skirt" to help break suction, and then pull from the base (aka the part under the skirt, at the top of your plug cylinder)
BOosted 335i
315
104
New Jersey
E90 BMW 335i
Well,I tried that and boot came out but left part of the inside on plug.looks like I'm up sheets creek.
1,634
Time for a new set of PR wires. ($70)
The new ones are an upgrade over the old ones. Make sure to put dielectric grease (a.k.a., silicone grease) between the rubber boot and ceramic insulator of the plug.
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
2015 M3, 2008 135i, 2009 335i
I had this happen to me with their original wires. The new ones seem much better. Contact them and they will work with you to get you a replacement wire or set.
1,685
New wires fit much better.
I did have an issue with several of my wires being pulled through improperly by the factory, meaning that they had to really be shoved in for the plug to clip on. This resulted in the plug and wire popping off, which is not good.
Sent photo proof and got new wires, no more problems.
Reactions: Davidwarren
