Pinacle Specialty Performance $200 Store Credit Raffle!
admin
NOTE: You must carefully read and follow the instructions a couple paragraphs down to be entered!
PRODUCT DETAILS:
This month we are featuring Pinnacle Specialty Performance as they and SpoolStreet.com have agreed to GIVEAWAY $200 Store credit toward their current and upcoming products!
Here is a description of the prize:
This means the winner can apply this $200 credit toward any products available or coming soon from Pinnacle Specialty Performance, including their Dual Carbon Intakes, FMIC, Inlets, and cooling kits!
Pinnacle Specialty Performance is set to debut an entire product lineup, take a peak:
N54 Dual Carbon Intakes [DCI]
The filters are made from 6 layers of a cotton gauze element that is washable. The filter media is wrapped over a surgical stainless steel mesh framework and high temp silicone ends.
Kit includes:
2 washable filters
2 clamps
2 3k matte 100% carbon fiber adapters
The adapters are a true 3k carbon fiber in dry or glossy finish.
Visit the link below for more details:
http://www.ebay.com/itm/PSP-N54-DCI...-Air-Filter-for-BMW-135-335-535-/232498845961
PSP N54/N55 High Density FMIC, all prices include Lower Chargepipe, local taxes and shipping CONUS:
600IC $524.99
750ic $629.99
900ic $734.99
Availability: Early November
Pre-Order: 335 Hi-Flow CNC Aluminum Outlets - $399.99
Dual Pass Oil Cooler Kit - $279.99
Dual Spal fan Trans Cooler kit with 180* Thermo switch:
For more information, feel free to contact PSP via their Facebook Page listed below!
INSTRUCTIONS:
To win, you must do ALL THREE(3) things:
  1. Like the Pinnacle Specialty Performance Facebook page and share their giveaway announcement to your own page - click here: https://www.facebook.com/FasterByPinnacle/
  2. Comment in the N5X Enthusiasts giveaway post (Check for Pinned Post), click here(Must be a member): N5X Enthusiasts
  3. Participate in the raffle (Located on home page). You may enter as many times as you want! Each raffle ticket is 25 credits, you earn them by posting replies(5+), making threads(10+), referrals(25), etc. If you look at the top of the page and see you don't have enough credits or you run out, the above actions will generate more. To enter the raffle click here and register: https://bmw.spoolstreet.com/raffles/
The drawing will automatically occur on the last day of the raffle month. Our system detects fake/duplicate accounts and offenders will be automatically disqualified. You may click "View Entries" to verify that you are indeed entered.
TERMS:
TERMS:
  1. Each winner will be vetted and required to answer a few questions to ensure integrity of the contest rules.
  2. SpoolStreet.com staff will verify the final winner is a member of N5X Enthusiasts and that the entrant meets the criteria listed here, if not a new winner will be chosen until the criteria is met. The winning entrant must respond and agree to the terms within 72 hours of the contest ending.
  3. Any charges, if any, related to shipping and handling are at winner's expense. The winner may not otherwise resell the prize within 6 months and must prove they have installed it on their own vehicle.
  4. This contest excludes SpoolStreet.com staff, ownership and vendor entities.
  5. An honest and detailed review with any applicable videos, photos of product and installation, logs and any other useful metrics which may be obtained, must be posted on this forum exclusively within 4 weeks of delivery of the contest prize. A detailed review with analytical references and media is expected. If you cannot ensure this, please transfer the winning rights to another eligible member who can.
  6. Terms are subject to change at any time. If contest staff determine there has been abuse of these rules, this agreement may be revoked and the prize may be requested to be returned or reimbursed. We reserve the right to disqualify an entrant for any reason.
  7. Due to the sometimes unpredictable nature of production, manufacture and logistics, delivery dates may be changed without prior notice.
4,328
This contest has been upgraded to include a $200 store credit for all PSP products!
2,191
Is outlet pipe offered for both stock and upgraded turbos with the larger outlet?
Nice giveaway!
Dusty Waterfall
42
52
Utah
2009 e92 335xi
More info on the oil cooler?
Dual pass front mount oil cooler with -10an male fittings welded to the end tank and laser cut 5052 aluminum brackets. The cooler has 4X the volume of the factory oil cooler of cars equipped with such. The OC with a t-stat delete lowers operating temps from 240-250 to 205-210 and dramitcally decreases the temperature ceiling. You would be hard pressed to exceed 230F with this oil cooler.
John6857
45
13
2007 E90 335i 6MT
Is it designed to work in conjunction with the stock oil cooler? and is it bolt up?
Thanks!
Dusty Waterfall
42
52
Utah
2009 e92 335xi
Thanks!
This designed as a standalone unit.
Available as separate pieces if you want to route differently or incorporate your stock cooler.
Cooler and bracket is $279.99
OEM T-stat delete plate with fittings and hardware $59.99
Lines and fittings for OEM style routing $179.99
John6857
45
13
2007 E90 335i 6MT
I will def look into this when i upgrade my oil cooler.
Thanks!
335i_lou
82
30
Raleigh, NC
E90 335i, FBO, inlets, outlets
Are you offering an external thermostat option with this too? Would be a nice combo to get the cooler, bracket, delete plate with fittings, lines, and external t-stat all together!
