I don't have a good picture since I wasn't thinking and cleaned up the leak before considering the possibility of a rear main seal leak.
Rear main seal replaced by local mechanic ~3 years ago / 7k miles (car was sitting for months) when transmission was out for a rebuild. I replaced the oil pan gasket in the same year (new bolts, carefully torqued with in/lb wrench and proper pattern).
Could an oil pan leak lead to oil covering the rear o2 sensors? the gasket is dry where its accessible.
I have circled the areas where oil is most prevalent before I cleaned it up (middle spot in picture is the access port, a few drops)
