OEM exhaust manifold/valve cover heat shield PN?
Seaneezy
133
34
e90 LCI 335i
Someone took a bunch of random spare parts from my sideyard including this piece that I need for my relocated inlets to protect them from the manifold. Does anyone know the part number? I tried making one myself but fitting it around the rear manifold is a real POS that cut up all of my fingers.
Seaneezy
133
34
e90 LCI 335i
13717649693
That's for the boost solenoid bracket, I still have that heat shield, I pried it off the bracket so I could fit the relocation inlets. I couldn't find it on realOEM so I'm assuming it doesnt exist, I'm just going to use clips for the time being and see how it stays on.
The Convert
1,486
1,040
There’s 13717649693, 11797558904, and 11797558905. If it’s not one of those, it doesn’t exist.
Reactions: Seaneezy
Seaneezy
133
34
e90 LCI 335i
11797558905
Yea it doesn't exist. #1 is for the solenoid bracket, I had to pry that heat shield off the bracket for the rear inlet, no big deal. #2/3 are the turbo heat shields IIRC, below the exhaust manifolds. I'm just going to clamp the one I made on and hope the inlet holds it in place during NVH. Thanks for looking, I guess I'll keep this thread up in case someone else is looking for it in the future.
iminhell1
419
207
Then the shield you're talking about wasn't stock. That is the only one that' was near the manifolds that came stock.
If you're talking something like this:
It came with the EVO inlets.
