NOZ Turbo Engineering DBB Hybrid Turbos
4,338
Here is another DBB offering which has a CHRA machined in Taiwan and a BB assembly constructed in Germany:
The turbos feature a TD04-15T lightweight billet compressor wheel with extended tip technology, a TD04 (9 blade) turbine wheel for improved efficiency whilst maintaining excellent spool characteristics and transient response.
- Dual oil seals on both the compressor and turbine housing sides.
- Custom CNC milled CHRA.
- Completely redesigned CHRA with 250% larger oil and water runner/reservoir. (Patented)
- Built-in oil restrictor.
- Direct fitment of the OEM oil/water lines, 100% bolt-on with no modifications required.
Supposedly they can sustain 30 psi and put out around 500whp on a Dyno Dynamics. I couldn't find any graphs though. Seems the GC Lites out class these unless they are under-reporting?
Nov 14, 2016
651
262
North Wilkesboro
Reactions: ATL-IS-N54
4,338
Here is a dyno.
Mods:
- NOZ Turbo Engineering dual BB turbos.
- VRSF 3" catless DP's.
- VRSF 7.5" Race intercooler.
- NOZ silicone/aluminium turbo inlets (OEM location).
- Modified rear turbo compressor discharge pipe.
- BMS DCI.
- VSRF charge-pipe with Turbosmart Kompact Plumb-back DV kit.
- Fuel-It Stage 2 LPFP.
- JB4
