I'm currently having issues getting my 335 back on the road and I was hoping I could get some feedback
Car is FBO / Motiv flex fuel / MHD tune by Wedge
TLDR version of the story is I blew out my mosfets, (30BB) sent them to a computer repair shop to get replaced, instead of replacing just the 6 he actually went and added an EXTRA mosfet on to the board. If you are familiar with what this DME looks like there is an open spot for a mosfet on the msd80 board. I don't know if this caused any issues before I noticed it and removed it. I tested all mosfets for continuity - no problems there.
the repair got rid of my 30BB code but afterwards I had injector codes (2E34 Fuel injector, cylinder 5, activation) and a misfire on cyl 2 (2E29 Firing Cylinder 2). I checked and found two injectors were in fact bad by testing them with my meter. Replaced all 6 with FCP remanned index 12's and coded them with inpa. I had to code them twice but I was able to get rid of that 2E34 code afterwards.
Now I'm trying to figure out this cyl 2 misfire, I checked a known working plug/coil combo for spark on cyl 2 and got nothing. I traced the orange power wire from the coil pack connector back to the ecm and found the wire was nicked. I fixed the power wire, confirmed the repair and tried to start the car. - no change. The signal wire is good as well so now I feel like I'm back at the DME again. I assumed if the DME was having issues I would get some sort of internal fault code.
Any Ideas? I'm just not convinced its my DME quite yet.
Thanks for any advice you guys can provide!
