Newbie question to tuning for pump fuel and hybrids
MoreBoost
389
Hi Guys,
long time N54 owner.
I'm wanting to run my car on pump fuel. 99ron which is something like 94 octane I think.
My car has 19T turbos, down pipes, HD 7.5 intercooler, no cats, cone intakes, 450 lpfp, BL coils and a JB4.
I've taken the JB4 back end flash JB4_IJE0S_HYBRID_RACE.bin which is for high octane gasoline or pump fuel+meth
There is a pump flash, JB4_IJE0S_PUMP.bin but no pump flash for hybrids.
I've adjusted timing(main) and timing (spool) down on the JB4_IJE0S_HYBRID_RACE.bin to pump timings.
Using timing cor factor (charge air temp) for pump fuel.
Boost request offset % is the pump value 90
Fuel scalar 1.10
I will target around 16 psi first and see how the logs are.
Does anything else critical stick out as being necessary to change.
Is this a better approach than just using the pump flash which was written for stock turbos?
Thanks
Fuel main 11.9
Did you try posting on N54 tech? They are usually very responsive.
I would be surprised to find out BMS does not have a OTS flash tune already for this.
Reactions: MoreBoost
MoreBoost
389
Can anyone give advice on the Timing (spool) table?
Pump uses this:
Race gas with hybrids uses this:
Timing on pump + hybrids:
Initial thoughts:
