New LPFP Controler
dyezak
1,767
1,518
Plano TX
335is
So who wants to get us some info on this? Looks to be a programmable EKP2 replacement that is integrated into the CAN BUS that can inherently control 2 DW400's or 2 Walbro 450's.
No more hobbs switch?
No more tapping into hot leads to power a second pump?
Maybe it's full time PWM control of both pumps at all times?
I have questions....
LoBoost
251
172
2008 135i, 2014 GTR
Hopefully all the above. I think I either need this, or I'll figure out what AUX pins on Syvecs will trigger a relay to kick on the extra pumps.
Milan
413
241
jebi se
your mom
I think Precision Raceworks has been working on one of these forever now. Would be a cool upgrade for sure.
LoBoost
251
172
2008 135i, 2014 GTR
So I emailed Torqbyte and asked if they could PWM control two pumps simultaneously. This is the reply:
Hi Matthew,
Yes it is. We have a special parallel Y pump harness for N54 applications. You can see a photo of it on our Instagram page.
The only thing gating the N54 release is some software testing we plan to complete in the next 2 weeks. Otherwise that will be the first BMW platform we suport.
Thanks
Alex
Torqbyte.com
Reactions: 9krpmrx8
LoBoost
251
172
2008 135i, 2014 GTR
One more reply, I asked how many amps it could handle:
It comes with a 40A fuse. You shouldn't need to (even with 2x DW400s) but if required you can run a 50A fuse as long as the unit is mounted relatively close to the fuel sender (under 3ft).
dyezak
1,767
1,518
Plano TX
335is
I wonder if it could control 3 pumps
Not with a 40a/50a max load rating.
But lets get real, a single Walbro 450 can push 600hp worth of e85...do you need 3 of those? Does anyone need 3 of those on this platform? People are hitting other limits of the LP fueling system and instead of properly addressing those limits they are just adding another pump.
Rcboosted2007
902
90
Parts unknown
07 335i
Erichale77
827
447
Clearwater, FL
07 E92 coupe
I am well aware of that and yes I do need 3. Alex at torqbyte got back to me and answered my questions. I have a solution now.
buster84
240
91
335 bmw xdrive
Has anyone thought about relocating the fuel pump to the engine bay?
The MagnaFuel MP-4303 is a high hp capible external pump that could work for this idea. I was thinking that you could replace the OEM fuel pump with a fuel hose that gets tied down to the bottom of the bucket, then add new -5an/8an fuel line from the tank to the engine bay, then you install the mp-4303 in the engine bay with a fuel pressure regulator that then connects to the hpfp. Seems like a cheaper and more reliable solution over 3 pumps, hobb's switch/control modules.
pysical
471
108
2009 335xi E90
2 Walbro 450s is enough to power 1000+hp.
