New aluminum coolant expansion tank option from Turner
Seaneezy
133
34
e90 LCI 335i
Doing my weekly ECS stalk and noticed this:
https://www.ecstuning.com/b-turner-...nsion-tank-relocation-kit-335i/021942tms13~a/
$500 for the whole kit
Been waiting for an update on the docrace concept ones for a while, this was a nice find. For anyone with a driver side plastic tank this could be a very useful replacement. For anyone like me who loves to spend too much money replacing plastic things in our engine bay, this is also very useful.
nswartz125
14
23
DIY 1m
500 dollarssss. Typical ECS lol. I like this but im still gonna wait a little longer on the DOC RACE tank. Doesn't seem like it will ever come to fruition tho.
Mikejones1208
145
115
Savannah, GA
2009 BMW 335i
Definitely expensive but I've yet to see a cleaner looking relocation kit, moves the power steering resevoir as well out of the way and tucks it in the corner, and i would assume coming from turner its all plug and play and doesnt have issues like not being able to fully lock the coolant level sensor in place or hugging your lower coolant line close to the serpentine belt
Reactions: InnovativeAuto
MDORPHN
196
162
BMW 1M
I would NOT assume anything about Turner any more. Although Will Turner kept Turner Racing, the other side of the business was purchased by ECS which reportedly eliminated any real R&D capability.
Neil
Seaneezy
133
34
e90 LCI 335i
Neil
Makes sense, they have been the primary n54 vendor on that site for a while anyways. I bought a lot of the ECS brand items in the past, namely the silicone rubber reinforced coolant hoses and they seemed to be good quality, definitely not from china.
add1ct
13
2010 335i
This is a very nice piece definitely pulling the trigger on this.
Boorda
175
99
Royse City, TX
futemire.com
328xi, 335xi M Sport
Anyone know whether it retains the coolant level sensor?
Neil
From these images it appears so....
Reactions: MDORPHN
I'd love to see someone buy this and do a comparison. I don't understand its design. It seems to "top" mount the tank, setting it high relative to the mount points. I've switched to the N55 tank which is far more compact - it will run with N54 coolant lines though they are a stretch. I'm looking at switching to the N55 coolant lines to the tank (p/n different than N54) as they look identical and it seems they likely provide a bit more hose length.
Anyway love to hear some hands-on feedback.
1,486
1,040
Did you go with the 335d coolant reservoir? It's a mirror image of the non diesel 335's and mounts right up.
You'll need to move the power steering reservoir as well, but I found the the 328xi has a bracket that mounts it to the strut tower which we have studs for.
You can also just use the 335d ps reservoir bracket.
Reactions: Boorda
Nope. N55 as I mentioned above. Bolts right up as is. I'm E89 (electric steering, no PS reservoir).
p.s. BTW props to @BQTuning for figuring that one out. I think he sleeps with realoem under his pillow.
The problem I found with the 335d tank is you have to raise it up on the fill above the strut tower or at least tilt it on a 45deg angle otherwise you could not get all the air out of the bottom line, the ecs one looks high enough not to cause this issue.
I prefer plastic tanks as they split, rather that if there was an issue than something else.
Looks good otherwise.
1,486
1,040
Why would you have to raise it? If it’s a mirrored copy of the 335 tank, it should sit at the same height on the driver’s side as on the passenger’s side.
  • Love
Reactions: Mikejones1208
In my situation, I'd only move the reservoir if I could get a clean and proper airbox on the driver side. Not really a fan of the sheet metal stuff.
Also curious if the CSF can be tapped on the passenger side so the expansion drain doesn't have to run all the way across.
LittleBlackHawk
Hi Fmorelli, have you ever tried the N55 hose lines? do they fit?
