Need the male fitting for lpfp line by sensor
Gavin
71
9
Montauk,NY
e92 Coupe
So I'm looking to redo the lpfp line connection just before connecting to the hpfp.now I'm still using the stock line so I need the part that's circled,if Martymil can pm me or just post here the part number or if anyone has the part# thanks.
Cruizinmax
128
73
09 335i
You're looking for a 5/16 efi push on fitting. Depending on the type of line you're running and arrangement there are a few choices.
Gavin
71
9
Montauk,NY
e92 Coupe
So I want to basically just do this,stock line thats in above picture and convert to the after market in pic below
Gavin
71
9
Montauk,NY
e92 Coupe
Didn't see your post martymil,just to confirm is the stock line a 5/16" size.you posted 2 different sizes martymil
Cruizinmax
128
73
09 335i
If the end goal is to eliminate that hard line you could also eliminate the 12" long oem soft line as well. All you would need is a 5/16 female quick connect fitting and make that pushlock hose another 12-16" long. Just an idea.
But it is 5/16 FWIW. I bought a few fittings to replace the soft line when I added my flex fuel sensor.
screaminfast
256
135
Rochester NY
mikecentola.com
07 SG/CR 335i / 17 X6 x35i
I was gonna do that too but decided against it because the LPFP sensor is M10, NOT 1/8npt as some have used. Talking with Tony from VTT seems to be that it’ll support upwards of 850+whp even with the stock line there.
