N54 swap 2002 build update
Kasmot
13
34
335i/2002
Just an update guys #justforfun
4,350
Nice work! Although I did notice you forgot to pull about the last 1 minute of audio before you exported.
What is next on the task list?
Kasmot
13
34
335i/2002
yea still learning.
But I was supposed to finish welding the front suspension but I decided to use the aluminum oil pan instead. So I’m back at fabricating/cutting part again ‍♂.
  • Love
1,630
Ugh this is like my dream build. 2002 with a modern BMW motor. so sick.
That’s what the guys were saying 10 years ago about adding an S54 to a 2002 in 2009...
... and 20 years ago in 1999 about putting an S52 in a 2002...
... and 30 years ago in 1989 about putting an S50 in a 2002...
... and 40 years ago in 1979 about putting an S38 in a 2002.
Some things never change.
JimboFresh206
289
152
335/635/535/533/633
Op what kind of chassis reinforcing are you planning on?
Are you staying with a small case?
Kasmot
13
34
335i/2002
Small case like the diff? I’m running e30 diff as well. So e30 front subframe fully modified and possibly switching it to tubular, e30 front suspension, e30 rear trailing arm as well as rear subframe
Reactions: JimboFresh206
JimboFresh206
289
152
335/635/535/533/633
Nice! Yeah the 2002s and e21s are ussually equipped with "small case" 168mm or so diffs.
That e30 unit is a "medium case" 188mm diff, and is considerably stronger. I don't think you'll see too many issues with it other than the clutches :)
Cool build!
Kasmot
13
34
335i/2002
Cool build!
Thanks man! Honestly would like to use a matching 335i diff w/ LSD lol we will see
