N54 starts then stalls
dano1107669
2008 N54 335i - engine starts then stalls after 10 seconds or so.
-No Fault codes
NEW - HPFP, Low pressure fuel pump (Precision Raceworks stage 2.5 v2, Throttle Body, low pressure fuel sensor, high pressure fuel sensor, catless downpipes, T17 turbos, MHD tune stage 2+, EKP (with coding), ignition coils, spark plugs, water pump, thermostat, MAP sensor on intake manifold, TMAP on charge pipe, and more
walnut blasted on valves under intake manifold
It would just crank without starting at all before I switched out the MAP sensor on intake manifold
engine ran before upgrades. There was fuel and coolant leaking from multiple locations so I decided to upgrade while replacing oil pan gasket, valve cover and gasket, etc., leak down test was good (cylinder 6 off by 7%), battery is good (new)
fuel pressures before and after engine stalls:
rail pressure - ~2500psi
low pressure - ~62psi
Why is it stalling? Electrical? fuel injectors? why no codes? it sounds like it's running out of fuel but isn't.
I have access to INPA, ISTA, and MHD
dano1107669
I tested the wires going to the fuel injectors with noid lights. The lights will flash showing that the injectors are getting power and signal while the starter is engaged. When II let go of the button to disengage the starter then press the button again to engage the starter again, it doesn't flash. If I turn off the ignition completely and try the sequence again, it repeats. This leads me to believe it's a computer problem.
I tested the wires to the coils and they are getting power while the ignition is on.
Any thoughts?
