N54 - Motiv Introduces the BoostBox!!
Chris@Motiv
150
Sav
With the ever increasing DME development and control its finally time to let it do what it was designed to do.
This is the official release of the Motiv Boostbox!
What is the Boost box?
The Boost box is a signal converter to allow the DME’s very high frequency output to work with the 35A Mac solenoid valve for single turbo users. This is a complete plug and play solution that will connect to your existing Mac solenoid or you can add a solenoid to your order if you don’t have one currently. It has also been programed to keep you within the limits of the DME and Mac solenoid so that you will never have any dead spots due to an out of range condition caused by WGDC or PID control.
Why the Boostbox?
-It’s a very cost effective solution to any single turbo user.
-50+ datalogging channels with MHD where you can see everything from tq limiters, vano req/actual, load req, actual tq, tq req, etc. The possibilities are endless to fine tune your N54.
-Allows your DME to communicate more precisely with your auto trans now that the TCU Flasher is around the corner. This is big news since the reported tq and load will now be on the same page with the TCU.
-Tune out your overboost on partial throttle! This is a very common problem on autos.
-The Mac 35A solenoid has been proven to provide very fast response and be bullet proof when it comes to reliability.
-Change boost with the load by gear option prior to flashing with MHD.
-Dynamic tuning.
-With MHD flex fuel, take full advantage of the infinite combinations and possibilities between load changes, based of ethanol content.
Why Motiv?
-Dynamic and adaptive tune tracing means you are not limited to a single column of cells. This means if your running 20psi your Timing, AFR’s, Vanos, Load actual, scalars, + more will be optimized for that load and it will all change as boost (load) increases or decreases. So, you’ll make more power at varying boost levels.
-Advanced PID control. This works just like the stock DME boost control. It will compensate for all variables and conditions keeping your boost on target at all times.
-There is no cookie cutter or one size fits all with our Full pro-tunes. Each unique car will have its own unique tune to best suit your goals while maintaining the best drivability.
- For you OTS users, we are now offering a pro-tune lite option with the purchase of a Boostbox! This will be a very cost effective option for those that want to get going on flash only without having to change WGDC or boost targets on their own but also don’t want a fully optimized pro-tune. The pro-tune lite will include a dynamic off-the-shelf style map with a few revisions to meet your boost target goal. This will also include our proprietary PID calibration to keep you on target at all times. What it won’t include is additional calibration to any other part of the map to get the most out of your particular set up. Pro-tune lite will include Pump, E50 and E85 tunes and will be VIN locked
-With many years of experience along with the latest DME development, we have restructured our tuning platform from the ground up to deliver the best driving experience.
Further development is always in the works and it will only get even better from here! Take the Flash only challenge and enjoy letting the DME do what it was designed to do!
Group Buy pricing:
Option A: BoostBox………………………………………………………….…..$150
Option B: Boostbox+Pro-tune lite…………………………………………$200
Option C: Boostbox+Pro-tune……………………………………………….$320 (15% off )
Group buy will last 2 weeks from Monday Feb 6th and there is no limit! Shipping will start shortly after we have a final number. Email [email protected] with which option you want and your user name and I'll add you to the list!
Chris@Motiv
150
Sav
Group Buy list
1. Rob.K.....................Option A
2. Skeletors E90..........Option C
3. William H................Option C
4. Mkster08................Option C
5. EricH77..................Option C
6. Shane....................Option B
7. Phil........................Option C
8. sshec152................Option A
9. Austin....................Option A?
10. Tuningservice.no....Option C
11. David335XI...........Option C
12. Misfitx4.................Option A
13. Frank G.................Option C
14. 08_335i................Option A
Beemin
37
Los Angeles
Does this allow you to control boost below spring pressure? Like how the stock turbos you can force open the wastegates under 0 boost.
mkster08
107
19
Kansas
Group Buy list
1. Rob.K..............Option A
2. Skeletors E90...Option C
3. Andrew?..........Option C
4. Mkster08.........Option C
5. EricH77...........Option C
6. Shane.............Option B
Chris, 3 and 4 are me, unless you had another andrew
