Datalog N54 LOW FUEL PRESSURE
keithkk1000
I'm having an issue with my low fuel pressure oscillation. I have dual pumps 535 & 450, full Precision Raceworks fuel system, top hat, lines, port injection with 5 bar regulator and return line. I'm also have speedsty ekp so no pwm, second pump triggers at 200nm.
It seems like I may need a 1 to 1 regulator or a better static regulator. I would appreciate any suggestions.
WOT log
Keith1k
9
I did resolve my issue.
I use my speedsty ekp to trigger my second fuel pump, it was set to activate at 200nm. The second pump was coming on way to early and draining the bucket faster than it could fill, at WOT it would drop pressure.
I set the trigger to 48% throttle which is where the reflex starts the PI.
Reactions: Desmo900
whyzee125
51
22
Glad you solved it! I was looking into the speedsty but didn't like that it makes both pumps non-PWM. I'm really impressed at how smooth your LPFP is in that log, way smoother than even PWM controlled ones on the stock EKP. Any downsides that you've experienced by moving to the on/off setup of the speedsty?
Thanks!
Reactions: baronmellick
Keith1k
9
It been working perfectly, I upgraded the wiring also. The company is solid. When I thought I was having an issue he worked with me to get it taken care of.
100% recommend!
Reactions: whyzee125
