There is a hissing sound...not there before at idle. Sounds like where the rear PCV area is located... when from a full stop, aggressive acceleration..the car will hiccup and then go right back to pulling strong as if nothing was wrong...but the more aggressive the pedal...the more strong the hiccup and will feel as if it will cut off the motor at some point.
My theory is the low side hose connection at the Valve Cover is leaking...and thus idle and low pressure driveability is affected. When pushing the pedal hard, the low side ceases to function and boost side takes over, but since there is a leak at the low side, the switch is being delayed to catch up with the abnormal vacuum state at idle RPMs.
Anyone ever had this happen?
I have lowside and highside catch cans and ports plugged.
