Buy the completely remanufactured record-holding BMW N54-G800 engine from Ghassan Automotive for $6,990. This engine comes rated at 800 wheel horsepower, and yes! It does come with our two years, unlimited miles, parts, and labor warranty. The N54-G800 is the engine set up used in our N54 record-holding 9.6-sec pass in the 1/4 mile. You will be getting a fully remanufactured N54 engine with our upgraded racing specs, upgraded bearings, custom forged rods, custom forged pistons, and ARP head studs. It is recommended to pin the crank ($495) or go with an aftermarket crank hub solution.
Ghassan Automotive wants to provide a stress-free and convenient experience. If you need a BMW engine replacement or want to upgrade the one you already have, Ghassan Automotive can do that for you. The process is zero-hassle from the moment we pick up the vehicle or engine, to rebuilding it and returning it to you. Engines are usually in stock and ready to ship.
Fully insured vehicle transportation rates are roughly 50-60 cents per mile, or engine shipment is a $350 flat freight charge. In-house engine installations are available with labor as low $1,995. No deposits are necessary unless custom parts are ordered.
You must contact Ghassan Automotive before shipping is arranged. There is a $1,000 core charge that is not included in the price and is refunded once the core engine is received. Core engines can be shipped to Ghassan Automotive in advance. All core engines must be in a rebuildable condition to be accepted. All payments must be made via certified funds.
Available engine upgrades at additional cost:
Thank you, Zoey
- CNC ported head $2395
- Upgraded Valve Train $1695
- Upgraded Cam Shafts $1495
- Closed Deck Engine Block $1195
- Cylinder Sleeves $1895
- Fire Rings $495
- ARP Main Studs $495
Thank you, Zoey
