N54 cranks but no start
DavidDeLeon335i
So I just swapped a new N54 into my 335i and also a ST Kit from on3 . Took the car to a car meet it ran fine and after we went on a small cruise. When I got home the car won’t start now it just cranks. Just seems strange it was running good before and I recently put a new battery in and coded it too, any help anyone?
here are the codes I scanned off the car
DavidDeLeon335i
Just wanted to update the thread incase someone had similar symptoms. The fix was a loose ground. It was the ground strap that goes from the dme to the chassis. I tightened it up and now the cars showed the gear it was it (which it wasn’t doing before) and then started up right away.
Makes sense because that kind of code set would have had me checking for a weak battery. Poor ground would present similarly. Whew you are lucky you didn't chase this for weeks on end!
