Does China GT follow SRO GT4 BoP or have their own BoP? The GT4 cars are "somewhat" different. Ie, the M4 has a true rear C/O. 718 Cayman CS have a Flat 6, whereas the roadgoing isn't even clear what Flat6 it's going to get.
This is awesome, keep it coming.
Very interesting that the 718 Cayman is 20kg heavier and still earns 70kg ballast. Looks very well developed leap ahead from the 981.
Edit: sorry i thought this was Asbjorn build thread lol I am referring to post #84 which shows the aluminum shrouding to all the coolers he has put into his car and is still struggling with temps. I just find it hard to believe doubling the radiator capacity did nothing. Either it's not getting air or it's not plumbed correctly and water isn't actually flowing through it.
I looked back through the thread and couldn't see much of your front bumper setup. Have you addressed AERO at all? You may actually have the cooling capacity you need you just might have to ensure air is flowing properly. There are an insane amount of minute details that go into a race-car and GT spec car that a lot of people don't notice. For example, the E92 M3 GT spec car BMW raced back in 2010-2011 used aerodynamically designed mirrors to draw hot exhaust out of the dump pipes and around the car...
You don't want air to be able to find ANY path around the oil cooler or radiator. If air can get AROUND the coolers it will NOT go through it. Path of least Resistance. All that bumper support that people hack out to fit large 7.5" intercoolers actually served a purpose. Look at OE fitment. Every little crevice is blocked off with either plastic or rubber strips. Same thing for the factory oil cooler... a duct funnels air to it from the bumper and then the slotted vent on the backside seals it to the fender liner. Look at the M4 GT spec cars front bumper in the above pics. Every single cooler is ducted and sealed to the bumper opening.
The vented hood is another excellent point. Every race car you see will have a vent right behind the radiator. A hood vent is in no way practical for any production car. Cooling is sacrificed by not having a hood vent to alleviate the pocket of high pressure air that forms from air hitting the front of the engine. Manufacturers compromise by trying to funnel the air underneath the car to keep the air moving around the engine. I think the factory intake design kind of exemplifies that. The scoops and ducting to the factory air box blocks off all the dead space above the radiator between the engine. The pocket of high pressure air it creates will serve to ensure that air flows down the face of the engine and under the car to exit...
Race cars go the opposite direction of this. They use body kits to seal the car to the ground (not lowering) and funnel all the hot air OVER the car and around it with hood vents and fender vents. This provide down-force, reduces lift, and massively increases airflow through the front fascia. Not so good for gas mileage or a daily driver but perfect for a race car.
Here is a quick link I found of some interesting bits about aero through a radiator. Event the radius of the bends in the ducting is important for ensuring you don't create vortices of air that restrict flow and do more harm than good: https://nasaspeed.news/tech/engine/...e-cooling-with-proper-aerodynamic-principles/
I think I've posted this here or maybe elsewhere but take a look at what Turner does with their M6... This car is amazing in person! A duct funnels the air from the back-side of the radiator right out the hood. The front fascia is completely sealed to the radiator. This car runs endurance races and doesn't need anywhere near the capacity or front fascia opening some of us have on our E82's. It looks so simple from the front bumper... almost factory street-car-like.
Wrapped/coated DPs will reject heat and raise turbine temperatures, EGTs. Tap and put an EGT gauge, and you will see. If the car has a good head (N54 exhaust valve is tiny), using ethanol/methanol fuels, sure. FBO/standard "fragile" turbos, definitely would not recommend. Each to their own.
@Asbjorn You could try a simple plate placed between the oil pan and downpipes similar to the head.
This makes so much sense - heat shielding the downpipes - this way even more heat goes out the tailpipe rather than radiate to the engine block.Watched a video about a guy solving a corvette overheating issue by heat-shielding one of the catalytic converters running close to the oil pan. It made me wonder if anyone has tried completely heat shielding against the coolant + oil lines and pan down there.
Was further inspired by below aftermarket turbo with built-in heat shielding. The M4 has something similar stock, and @Hydra Performance obviously thought about it as well.
If working on this benefits engine cooling (coolant, oil), it would perhaps also explain why some of the single turbo owners claim that they do not see overheating on track.
I agree 100%. You really need good air flow through the radiators and coolers to maximize heat removal. Of the three ways to remove heat (radiation, conduction, and convection), convection by moving the cooler air over a hot surface is most effective way to cool.Does anyone here know if the temperature differential across the radiator / engine can be read with BMW diagnostic software while driving? According to the N54 documentation, there should be a temperature sensor both at the engine outlet and at the radiator outlet.
If we could read both temperatures, it would allow us to determine if the coolant flow is adequate. If engine out is 230F while engine in is 158F, then turning up the flow alone should be enough to keep temps down. If engine out is 230F while engine in is 212F, then there's a radiator or air flow issue.
In my build thread, I have documented the build and test of a new setup consisting of CSF + three aux radiators w/ booster pump and improved ducting. While an improvement, I am still not satisfied with the performance (tested at 100-110F ambient). I need to figure out if the OEM electric pump is actually the bottle neck, despite theory saying it shouldn't be.
Everyone I have spoken to from the racing world, claim that I just have an air flow problem. They say air flow solves everything. The counter argument then being that air flow wasn't improved between the M2 and M2C, yet only one has an overheating issue. Yes I know the side ducts were enlarged, but...
I think early N5x had a rad outlet sensor, mine doesn't. For those without the outlet sensor, a substitute value of ECT (at the head) minus 7.5C is used for the TCO2 value, so logging the delta through the DME won't shed any light because it's constant. If you have the rad outlet sensor, can monitor in INPA, log with Testo and maybe others.Does anyone here know if the temperature differential across the radiator / engine can be read with BMW diagnostic software while driving? According to the N54 documentation, there should be a temperature sensor both at the engine outlet and at the radiator outlet.
