N54 Codes List
4,291
This is a list of codes I found online. They may be out of date, let me know if any if anything is wrong or could use updated.
HexidecimalDecimalDescriptionNotes
29CD10701Misfire cylinder 1Change spark plugs
29CE10702Misfire cylinder 2Change spark plugs
29CF10703Misfire cylinder 3Change spark plugs
29D010704Misfire cylinder 4Change spark plugs
29D110705Misfire cylinder 5Change spark plugs
29D210706Misfire cylinder 6Change spark plugs
29D910713Misfire in case of tank filling lowFuel tank too low. Fill it up!
29DC10716Cylinder injection switch-off
29E010720Fuel Mixture Control 1
29E110721Fuel Mixture Control 2
29E210722Fuel injection rail, pressure sensor signal
29F310739Fuel pressure sensor, Electrical
29F410740Catalytic converter 1 inefficiencyLower o2 modifer value
29F510741Catalytic converter 2 inefficiencyLower o2 modifier value
2A1710775DMTL diagnosis module tank leakage, system failure
2A2D10797Differential pressure sensor, suction pipe: adaption
2A8010880Inlet-Vanos variable cam control test, input signal
2A8710887Outlet-VANOS variable cam control test
2A8510885Outlet-VANOS variable cam control test
2A9410900Crankshaft sensor, signal
2A9A10906Camshaft sensor inlet, signal
2AA110913Camshaft sensor outlet, signal
2AAF10927Fuel Pump PlausibilityOften triggered when running a tune
2ABC10940Charging pressure sensor, electrical
2ABD10941Intake pressure sensor, re-running
2AD010960Gear Control
2C2B11307lambda probe in front of catalytic converter, system check
2C2C11308lambda probe in front of catalyic converter 2, system check
2C3111313Lamba probe in front of cat 1, trimming controlo2 sim to strong. Raise o2 modifier setting
2C3211314Lamba probe in front of cat 2, trimming controlo2 sim to strong. Raise o2 modifier setting
2C3311315o2 sim to strong. Raise o2 modifier setting
2C3C11324lambda probe in front of catalytic converter, not plugged
2C3D11325Lambda probe in front of catalytic converter, control failure
2C6211362
2C6A11370lambda probe behind catalytic converter, muddledo2 sim to strong. Raise o2 modifier setting
2C6B113712C6B Lambda probe behind catalytic converter, system check
2C3E 11372Lambda probe in front of catalytic converter 2, control failure or cable transmission failure?
2C7311379Often triggered during the firmware update process… normal. Just clear the code.
2C74 11380Lambda probe behind catalytic converter 2, signalOften triggered during the firmware update process… normal. Just clear the code.
2C7B11387Lambda probe behind catalytic converter, signal
2C7C11388Lambda probe behind catalytic converter 2, signal
2C7E11390Lambda probe behind catalytic converter, trimming control
2C7F11391Lambda probe behind catalytic converter, trimming control
2CAB114312CAB Lambdaprobe 2 before catalyst, temperature
2CA7114352CA7 Lambda probe heating in front of catalytic converter 2, function
2D1811544Often triggered when running a tune
2D1C11548Accelerator pedal module, pedal sensor signal 2
2D2E11566Angle of throttle valve- intake pipe underpressure, correlation
2D2511557Mass Air Flow Excessive - External Tuning Box DetectedOften triggered when running a tune
2D2E11566
2D5811608DME digital motor electronics, internal failure: control nominal torque?
2D5A11610Control motor torque limitation
2DC311715Control clamp 15
2DC311756Power management, battery control
2DED11757Power management, standby current control
2E8411908Electrical cooling pump, communication
2E8D11917Intelligent battery sensor, signal transmission
2EE012000Coolant temperature sensor, signal
2F0D12045Radiator blind, input signal, (GLF)
2F4F12111
2F6C12140Exhaust fumeflap, input signal
2F8112161Engine shut-off time, Time counter Instrument Cluster - Time counter DME, Comparison
2F8312163 Engine shut-off time, Time counter Instrument Cluster - Time counter DME, Comparison
2F8F12175Accelerator pedal module and brake pedal, plausibility
2C6B11371
2EE012000Coolant temp sensor, signal
2EE312003Coolant temp sensor, plausibilty
2F3012080
2F9E12190Termic oil level sensor
2FBE12222Fuel pressure after motor stop
2FBF12223Fuel Pressure at Injection Release
2FC712231
30BE12478Injector, calibration plausibility
30CF12495Wastegate, input signal
30F112529Glow ignition: cylinder 5Excessive knock
30F212530Glow ignition: cylinder 6Excessive knock
30FC12540Exhaust fume turbocharger, Density
30FE12542Exhaust fume turbo charger, high pressure sideOverboost
30FF12543Exhaust fume turbocharger low sideUnderboost
310012544boost-pressure control, deactivationThe no boost limp mode caused by another fault code
508820616Sensors gear selector switch
51B020912DSC Signal not plausible: Brake pressure signal
5DE024032DSC-ECU: ECU-internal: Plausibility of the VASP-U_Bit versus Uz power supply_clamp_15.
5DE124033DSC-ECU: ECU-internal: Clockstatus of the SP interface shows missing clock.
5E1A24090DSC-ECU: ECU-internal: Serial-Peripheral-Interface (SPI): Transmission failure multi IC
5E4024128Wheel speed sensor rear right: Signal edge missing(RDF-Typ11i).
5E5B24155Stability control - Wheel speed sensor general: Long-term (several seconds) error suspicion of 3-4 RDF led to error mode.
A09241106SHD Standardization 0xA092
A0B041136Ecu input brake lights
A0B441140Fault engine start starter
A37541845Communication with airbag ECU disturbed(Error_IBUS_CONNECTION_FAIL)
A3AD41901CAN ID 1D0 error: Engine data
A3AE41902CAN ID 0AA error: Idle engine speed
A55442324Alive telephone
A55942329Clamp 30g_f cutoff
A8B643190Error will not cause a warning light
D35454100PT-CAN: Message TORQUE_1 (ID 0xA8) not received or wrong message length (DLC). [transmitter: DME]
D35554101PT-CAN: Message TORQUE_2 (ID 0x0A9) not received or wrong message length (DLC). [transmitter: DME]
D35654102PT-CAN: Message TORQUE_3 (ID 0xAA) not received or wrong message length (DLC). [transmitter: DME]
D90455556K CAN wire error
E71759159CAN message: Dates of engine
E71A59162CAN message: Torque 3
[TBODY] [/TBODY]
808AWD325xi
Austin, TX
2F83 & 2F81 are missing from the list. Per Google translate:
2F83: Engine shut-off time, Time counter Instrument Cluster - Time counter DME, Comparison
2F81: Engine shut-off time, Time counter Instrument Cluster - Time counter DME, Comparison
AZN54
32
19
Mesa, AZ
Can anyone elaborate on the solution for 2C32? I'm getting this code along with 2C6C-Oxygen Sensor 2 after Cat Converter
[TBODY] [/TBODY]
Newly installed Doc kit within 1000 miles. I figured I burned up the sensor, so I replaced pre-cat bank 2 o2 (with NTK) to no resolve. Ordered and plan to replace post-cat downstream o2 (Bosch) this weekend. Research points to a bad post-cat sensor can throw codes for pre-cat or a possible exhaust leak. No major leak detected.
I'm assuming raising o2 modifier setting is something my tuner will need to do (MHD).
Trying to come up with a checklist of things to consider while I tear into this weekend. I can provide idle and cruising logs.
Happy to start a new thread if needed.
