Exterior:
M4 rep trunk spoiler
Custom side splitter
Custom front splitter
Custom grill mesh
Meteo Motorsport defuser
Hard Motorsport center lock wheels
Lci tail lights
Accorsi engineering dtm headlights
Smoked side markers
Interior:
Recaro profi spg
Coby Wheel gauge hood,shift boot,hand brake,hand brake boot and steering wheel
IRP shifter
Aem wide band for each bank
Aem boost gauge
Aem oil pressure gauge
Macht Snell gauge pod
Turner Motorsports pedals
Ultimate clutch pedal
Carbon sun roof delete
Brakes:
Hawk race pads front and rear
Braided lines
Titianum shims front only
Repainted calipers (silver)
Stop tech slotted rotors front and rear
Motul 600 fluid
Drive train/suspension:
M Factory twin disk clutch (full race)
Akg end links
Ecs sway bar front
Akg sphirical lower strut mount
Akg poly upper strut mont
Godspeed toe/upper control arms (spherical)
Polly lower inner rear
Rouge engineering lower outer rear(bearing)
Rouge engineering trailing arm bushings (bearing)
Ecs trailing arms
Tuner solid subframe bushings
Turner solid diff bushings
650i finned rear diff
M3 steering rack
M3 control arms front
Akg spherical inner uppper front
Akg end links
Ecs sway bar rear
Akg 74d trans mount
Dssr
Ast coilovers
Custom diff lockdown
Active autowerks strut brace
Toyo r888 245 front 265 rear
Ade engine mounts
Wavetrack LSD
Vorshlag camber plates
Engine/Fuel:
MMP Turbos
Ade port injection
Aem meth (sprayed into the hot side endtank.
Big Tom intercooler
Vrsf down pipes
Vtt inlets
MMP outlets
Eas charge pipe
Tail bov
Stainless vac lines with quick disconnect
Stainless occ lines
Rb pcv valve
Mishimoto occ
Evolution race works carbon engine cover
M3 cowl
Carbon M3 cowl cover
Ecs carbon intake
Custom oil cooler
Bimmer life ignition coils
Custom stage 3 lpfp with twin hydramats
Custom secondary fuel controlor
Mhd flash only
Tuned by Wedge
Aic secondary fuel rail controlor
Ecs oil fitter cap
Ecs coolant bleeder
