mirror retrofit, lots of issues now
1,286
781
I did a retrofit of the self dimming mirror. The mirror I had was just the plain no features but the alarm light.
I replaced it with a self dimming compass mirror with alarm light. I ordered the retrofit cable, and installed it as per instructions. The mirror works fine, dims as it should, as does the compass.
I must have done something wrong, because now I have the following issues:
No alarm chirp when locking or unlocking
Interior lights no longer work
sunroof no longer opens or closes (thankfully it was closed!)
Passenger airbag message on dash (appears related since there is a light in that overhead console.
light and rain sensor not working - lights always on if in auto
My old mirror had 3 wires, which were replaced and supplemented by the 5 wires in the retrofit harness.
I still need to check fuses to make sure something else didn't blow, but any suggestions as to what the issue may be? Could the entire overhead module have gone bad?
NoQuarter
1,662
1,067
Indiana, USA
Z4 35is, 535xi, X5 35i
The mirror is getting power and the dimming part is self contained to the mirror. The parts not working all seem to be external communication from/to the mirror.
So... bad pin connection, wrong pin connection, coding of some sort?
All I got at the moment.
1,286
781
Step 1 - check basics.
It was the 7.5amp fuse for the overhead console. Im a dummy and didn't do the basics first. Very weird that the mirror got power while nothing else did.
Reactions: NoQuarter
