MHD Stage 2 Overboost?
pysical
446
105
2009 335xi E90
I have a friend who has a 2010 N55. He just recently took off the Jb4 and went with MHD. He put on Stage 2 because he has the DP for it and stuff. Anyways, he recently got 2 codes:
2C56 - Charging pressure control, plausibility Pressure too high.
2C58 - Charging pressure control: Switch-off as consequence
Here is 3rd gear manual mode
https://datazap.me/u/pysical/dan-manual?log=0&data=3-11
I can't find anything about if the MHD Stage 2 needs the 3.5 bar map sensor, or what is going on. But as I was the one driving it did not feel like he built 20 psi in 900 rpm.
Anything to check that may be the issue?
1,929
664
It does not need the sensor. I would make sure that he didn't click any flash time option for different sensor or anything i know n54 stage 2 Is 18 psi but that could also be a faulty sensor. Depending on elevation 20 psi is pretty much tilting sensor i believe 22.5 is logic limit and accuracy it's seriously inaccurate at 20 and above.
