MHD 2.0 with Datalog API Integration
4,348
You can now upload datalogs with the MHD->SpoolStreet Integration available in MHD v2.0, there are two ways to proceed:
  • Upload logs with an API Key:
    • Logs will persist indefinitely at https://datalogs.spoolstreet.com/ under "Your Datalogs".
    • BB Code support to embed your datagraphs in posts and PMs.
    • Additional privacy options such as a true Private setting, so only you can view even if someone has the link
  • Upload logs without an API key:
    • Logs will automatically delete after 14 days, if you lose the link there is no getting it back
    • No registration required
If you want logs to be saved to your account automatically, click "Find" and you will be sent to the API Keys manager:
You may have to login/register and then go back to the app and click "Find" again to be redirected correctly. From the API Keys manager, click "Add API Key" in the top right:
Then select the graph:write API permission, add a name and click save:
Copy your API key:
Then go back to MHD and typed it in:
Once the API key is added, you will not need to login anymore and all the logs will be connected to your account automatically.
By default, logs uploaded without an API key will have the 'Unlisted' privacy setting. This means it won't be displayed to the general public, you MUST know the URL to the datalog in order to view it. This also means if you lose the link, it is gone forever.
If it wasn't clear how to upload a log, you swipe left on it.
To move your licenses to iOS, first login on Android then login in iOS.
If you have login issues, ensure you have Google Chrome downloaded on the device and use that browser to login instead. Don't use the phone's built in browser, just use Chrome.
Alternatively, try logging into the updated Android app with a different device temporarily just to get your licenses uploaded.
Bigfwop
24
20
Fort Myers
e92 335i
You can now upload datalogs with the API, there are two ways to proceed:
  • Upload logs to your SpoolStreet account using an API Key, logs will persist, have privacy options and be available indefinitely in the datalogs section(https://datalogs.spoolstreet.com/) under "Your Datalogs".
  • Upload logs without an API key, logs will automatically delete after 14 days and if you lose the link there is no getting it back.
If you want the logs to be saved to your account, click "Find" and you will be sent to the API Keys manager:
You may have to login/register and then go back to the app and click "Find" again to be redirected automatically. From the API Keys manager, click "Add API Key" in the top right:
Copy your API key:
Now you will not need to login anymore and all the logs will be connected to your account. By default, logs uploaded via the API will be 'Unlisted'. Which means, they won't be displayed to the general public, you MUST know the URL to the datalog in order to view it.
I've never had to log into MHD via Android. Is this something new?
4,348
With the new MHD app, you'll encounter it's own login system. There are several benefits to this likely, but mainly it enables you to transfer your licenses between Android and iOS. For additional clarity, this has nothing to do with the integration with SpoolStreet's datalog API, it is a separate MHD specific thing.
Bigfwop
24
20
Fort Myers
e92 335i
The entire process makes sense. I guess I have to wait for Google to push another update out. Currently I'm rocking v1.92 and there is no login system for me to update my licenses to so I believe they're just local to my device.
4,348
You should check again, it was available for me just not too long ago. These screenshots were taken using the Google Play version. I'm in North America if that matters.
Bigfwop
24
20
Fort Myers
e92 335i
I found my problem. I've been bamboozled via google play. I've always been able to pull updates no problem but my current os is 4.3 Jellybean and apparently their new requirements are 4.4. Now I have to root my phone and update is manually since my device is archaic.
  • Wow
4,348
Oh bummer, looks like Android isn't giving up that easy! It's going to keep you around for as long as poasible
houtan
654
333
135i N55 DCT; PS2
I haven’t looked yet but does the data log feature work with the N55e e series version as well?
4,348
I have specifically tested the following:
MHD
BM3
JB4
COBB
BPM-4
MG Flasher
Basically anything that is in csv format although it has special support for JB4 and BPM4 since they have extra headers. If you click the 'Datalogs' on the navigation menu here, you can see which logs are detected, it shows their app icon.
houtan
654
333
135i N55 DCT; PS2
MHD
BM3
JB4
COBB
BPM-4
MG Flasher
Nice!! Looking forward to trying this out. So much more convenient.
4,348
Got it to work! Very easy. So my logs upload to the General category. Is that correct?
I saw there was an N55 category but didn’t see an option to choose it.
In order to select which category the MHD will upload your logs to, we'll need to wait for @jyamona to clear his backlog of items, hopefully he will add that support, I've provided the information on how to do this already. The only way to get it in a specific category for the time being, is to visit the Datalogs section and upload manually or ask me to move it.
Reactions: houtan
