LPFP support for HPFP rail pressure
3,642
I found the ekp2 has a hard time controlling the LPFP pressures smoothly, switching to ekp3 on my 335 smoothed everything out.
No problem for the ekp3 controlling the 535 pump with no active cooling and in one of the hottest climates on earth.
It's easy enough to change. I'd swap the pump and see how it goes. If you end up seeing control issues like Marty, then you can always look into doing the EKP swap after.
Reactions: Mzfhartge
