Even if you flash the DME to run the pump faster -- as I can do with MHD, am I correct that the lower limit will be the temp at which the thermostat opens (which I believe is 97 C/207 F)?
Or is the stock thermostat itself electronically controlled so that the flash tune can set it to open at a lower temp?
Thanks.
EDIT: Just found a post from my old friend JamesM3M5 that answers my question:
"The ECU will regulate both the thermostat opening and water pump speed to maintain the proper temp. The two wires going to the thermostat are for a tiny heater that will heat up the wax plug and open the thermostat earlier than its advertised temperature."
Neil
Thanks.
Neil
