Laggy S372XE Single Turbo Build
Hknba
Hi, i have a 335i Manual with a Speedtech Bottom Mount Kit.
The turbo is a Borg Warner S372XE with a 0.91A/R T4 Divided Housing.
The car has been fun to drive and really reliable but i am getting tired of the Turbo Lag. I hit full boost (30PSI) at 4800rpm.
I wanted to ask if my boost coming on that late is normal and if there is anything that can be done to decrease the Lag before going to a smaller Turbo.
I would also be interested in your opinions in general about the Logs and Dyno Charts i attached, because i bought the car already built and i would like to know if theres anything that should be changed or looked at.
Build details:
Mahle Low Compression Pistons
FCP H Rods
BMP Port Injection 750cc
Walbro 450
Motiv Reflex+
Its my first post here so feel free to ask any questions, i would be happy to provide more info/details.
  • 100 Oct 1.8 Bar 650PS 2024-03-08 18_17_46 I8A0S Fabian_SpeedTech_MHD+_v11.mhd.csv
  • E20 2 Bar 755 PS 2024-03-08 18_20_13 I8A0S Fabian_SpeedTech_MHD+_v11.mhd.csv
  • E92 N54 Single Turbo (1).pdf
  • N54 Single turbo (3).pdf
ktb_e92
83
41
Indiana
2007 335i MT6
Hitting 30psi at 4800rpm with that turbo / turbine housing size is actually pretty good, I wouldn't be concerned. Your tuner can always make any turbo spool up faster with some timing & fueling adjustments along with the boost ramping in earlier RPM's, but internal durability will become a concern at that point due to torque levels. Now, since you have upgraded pistons and rods, you'll definitely last longer than a stock motor if you want your tuner to make the boost set in a little sooner if possible, just be careful with how frequent you use the power around that area
Reactions: seb.apprenti
