Just Updated MHD and Flashed 9.0 Now Car Doesn’t Start?!
1,620
Hi Everyone,
I just updated MHD and reflashed V9.0 Stage 2+ OTS map with FlexFuel option (E27 in the tank). Only changes from yesterday, when car ran the same tune just fine other than cat codes, was to crank up the new throttle sensitivity slider to “1M” and turn off boost per gears 1, 2, 3.
Car cranks but doesn’t start. LPFP is 72psi while cranking and HPFP is 2500 psi while cranking.
Any ideas???
Thanks,
Jeff
Jern54
290
Netherlands
E91 N54 335i
Ken:
It's highly possible that the phone that you're using is corrupting the temporary file. You can always email the flash.enc file from the debugging folder to MHD
Martial@MHD
Oct 24, 2016
13
46
Hi Everyone,
Any ideas???
Thanks,
Jeff
email us [email protected] to get this sorted.
You can uninstall the MHD app, and install the previous build from https://m.apkpure.com/.../com.../variant/version%202.25-XAPK
REfalsh your car (make sure it's 2.25 in the main menu). If the car starts all fine, then remove this 2.25, install 2.30 from the play store, and use "send debug files" in the main menu so we can compare the flashes on 2.30 and 2.25.
Jern54
290
Netherlands
E91 N54 335i
Jern54
290
Netherlands
E91 N54 335i
Email has been sent with debugging files.
The car started directly after flashing it back with 2.25.
Updated the app to 2.30 flashed the car and same happened again. It only cranks without a spark. Hope to provided sufficient information.
Reactions: Jake@MHD
1,620
Same result for me, too. MHD emailed me a link to V2.31 which forced a long flash (10 min on OBDII cable) and all is well. MHD replied quickly and followed up too. Great customer service. Thanks!
Reactions: Jake@MHD
